01-03-2017, 03:28 AM | #1 |
superstreet
Drives: 2012 SS/RS Drop Top Join Date: Jul 2011
Battery
How long is everybody's batteries last. I have a 2012 SS convertible with 55,000 miles. When can I expect to have to change it.
01-03-2017, 05:56 AM | #2 |
Started#gottalovethatblue
I have a 2010 with 45k+ on my car and I'm still on the original battery (vehicle born on date of July 09). I may however, have to change it this year. First start last year was a little sluggish.
01-03-2017, 07:03 AM | #3 |
H-Town Camaro Club
Drives: 2013 Dusk Edition 2SS/M6/Sun/NPP Join Date: May 2014
OEM Batteries were built like Russian Roulette. Depending on cycle, age and weather they will die every 15,000 or last 100,000. The "part" was built to fail with little quality control, if any.
One of the first mods I did within 6 months from the dealer was replace the battery with an AGM.
01-03-2017, 07:49 AM | #4 |
376 cubic inches of fun
Huge variation in battery life depending on your usage.
My battery was OK after 7 years, but I changed it as preventative maintenance. I'm sure some will post here about much shorter battery life. |
01-03-2017, 08:00 AM | #5 |
Drives: 2014 2SS/RS Join Date: Jan 2014
Looking at where you're at, I'd be getting a little nervous. In the desert, a battery will die with absolutely no warning. I went to dinner once with a four year old pickup (in Phoenix), all was fine when I arrived, but after dinner, the battery was dead flat. The heat will kill it pretty quick unless you're lucky!
01-03-2017, 08:00 AM | #6 |
my car was built Dec. 2009 and changed battery in 2015.
01-03-2017, 08:25 AM | #7 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
2010 2SS, original battery with 43k miles on it. I keep it on a tender when not in use.
01-03-2017, 09:56 AM | #8 |
[COTW 4/13/15]
Drives: Supercharged LLT Join Date: Jul 2010
My '10 (build date 09-14-09) was going strong until a Kaufman tire place did some diagnostic test and killed it (almost). Luckily, it didn't completely die until next week (September '15). Replaced with a Braille 21lb battery.
01-03-2017, 09:58 AM | #9 |
Drives: 2011 Camaro 2LT/RS Join Date: May 2015
replaced my OE battery last month. 65K miles.
01-03-2017, 10:48 AM | #10 |
Drives: 2011 Inferno Orange Camaro 2SS/RS Join Date: Nov 2011
2011 about 36000 battery original and still going strong *knocks on wood*
01-03-2017, 11:26 AM | #11 |
Drives: 20’ Chevrolet Camaro 2SS 1LE Join Date: Jan 2009
They usually last 3-4 years depending on use. For for accurate results use a volt meter, if the battery shows 12.1-12.3 V while engine is off, expect replacing soon!
01-03-2017, 11:31 AM | #12 | |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
of gas before filling up? I replaced my early '10 SS battery 2 years ago just because I didn't want it to fail at an inconvenient time.
01-03-2017, 11:38 AM | #13 |
01-03-2017, 12:22 PM | #14 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Be 7 yrs in March. Just now starting to show signs. Every battery is that way.......as stated, all depends on usage...extreme climate, etc.
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
