12-27-2016, 01:24 PM | #1 |
Drives: 2012 Camaro RS 45th Aniv. Join Date: Nov 2016
E-85
Is it possible to run E-85 without any modifications to the OEM fuel system.
The car is a 2012 Camaro Rs with a 3.6L V-6. Any advice is appriciated! |
12-27-2016, 01:36 PM | #2 |
You need a flex fuel sensor and some upgrades as E85 required more fuel to be burned. So a bigger pump and injectors are usually in order.
What mods do you currently have. E85 won't offer much of a performance upgrade on a stock motor. |
12-27-2016, 01:39 PM | #3 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
You need these components and tuning software to enable the sensor and adjust a few settings.
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
12-27-2016, 02:09 PM | #4 |
I just have intake and exhaust. I just want to get some of the small stuff done befor i do the big stuff to it.
12-27-2016, 02:16 PM | #5 |
12-31-2016, 09:55 PM | #6 |
01-01-2017, 01:43 AM | #7 |
so i got a blue driver for chrismas and looking through the info it said gasoline/e85 so my car is already e85 i guess
01-01-2017, 11:27 AM | #8 |
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3 Join Date: Jun 2010
E85 has less energy and you might get some MPG increase but you'll need to burn more of it.
Why can't you just keep running gas?
01-01-2017, 12:49 PM | #9 | |
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
How do you get better mpg if your burning more fuel. I have a company car, Impala, with flex fuel and I get less miles to a tank with E85 than regular 91 octane. Just curious, thanks. |
01-01-2017, 01:04 PM | #10 |
Drives: 2013 1LT RS Camaro Join Date: Apr 2016
E-85 will give you less gas mileage, around 20% less. With tuning changes you can get more rwhp using E-85. Depending on what mods you have, you can get up to 302 rwhp with an auto and upto 316 with a manual. Overkill has the conversion kit and the tune for E-85.
01-01-2017, 02:26 PM | #11 | |
Buick 455 Fan
The question is: why are you interested in running E85? My opinion of it is somewhere between a worm's belly and the IRS audit man.
01-02-2017, 02:23 PM | #12 |
so it says gasoline/e85 so am i already e85? Sent from my iPhone using Tapatalk |
01-02-2017, 02:34 PM | #13 |
Drives: 15 Z28, 01 Corvette, 96 Corvette Join Date: Dec 2016
If he wants to add a blower its a valid idea. If not then no reason. I have considered switching to E85 several times. There isn't an E85 station around my home town. My Blown Vette would enjoy E85.
01-02-2017, 06:01 PM | #14 |
Drives: 2021 ZL1 1LE Join Date: Aug 2010
I run E-85 and picked up 60hp and got rid of the meth kit in place. I replaced pumps, fuel lines, and injectors with my upgrade
