![]() ![]() ![]() Drives: Garnet Red - 20 ZLE Join Date: Jun 2016
Check Engine Light Question?
Car is under warranty still but figured I would throw this out there in case its an easy fix, Im not without my car for a week.
P06DA P06DB Engine light came on and said reduced power. Car drives fine and idles normal when the code is cleared. Has good oil and fuel pressure from what I can tell. Any GM tech's could chime in maybe and let me know what you think 2017 SS M6 Last edited by slick3; 04-11-2017 at 10:39 AM. |
Found out the issue. You guys might want to check for this next time you are under the hood. Car has 300 miles on it btw... This is the sensor located directly to the right side of the crank. It is a pressure actuated solonoid harness to regulate oil pressure.
Thanks to Tim, @ EFI Tuning for help me get this figured out. Im going to try and fix it myself, unless the engine goes bye bye, there is no way this thing is going back to the dealer. ![]()
Is the issue with how that wiring harness is routed and it got too close to the belt which chewed a hole in it? I may be stating the obvious but sometimes you don't see all you need to know in a photo.
![]() ![]() Drives: 2016 Camaro 2SS, NPP, A8, FBO, E85 Join Date: Oct 2016
hey can you repost the pictures? I am also dealing with the code P06DA and I wanted to know what you did to fix it?
Well............ At least you tried. lol
![]() Drives: 2018 SS 1LE Join Date: Sep 2018
#7 |
I’m throwing this code! What was the fix?
#8 |
![]() Drives: 2022 Vivid Orange Metallic LT1 Join Date: Mar 2020
I have the same code. Here is a pic of what is wrong.
| Tags |
| check engine, p06db, po6da |
