12-20-2016, 11:11 AM | #1 |
Remove Duragloss Rinseless
A few days ago the grandkids got hold of my Duragloss Rinseless spray bottle I use for just doing touch ups. They sprayed most of my wife's car with it and 2 days later it looks white dried road salt. Wife caught them but it was raining when it happened so she figured it would just rinse off and didn't tell me. Any suggestions? I fear it's going to require a full strip/polish, its 34 degrees outside.
12-20-2016, 11:12 AM | #2 |
Retired from Car mfrs....
Wash it with Dawn, rinseless has no strength to it.
12-20-2016, 02:42 PM | #3 |
Thanks, that seemed to work on the body but seems to left spots on windows. Tried some glass cleaner but didn't work.
12-20-2016, 02:44 PM | #4 |
Vinegar or straight alc on glass
12-23-2016, 05:27 PM | #5 | |
Drippin' Wet Auto Detail
http://www.detailedimage.com/wax.php...912/500-ml-S1/ |
12-23-2016, 08:29 PM | #6 | |
They don't recommend Carpro Spotless to be used on glass. Copied from product description @ Carpro USA for Spotless. Do NOT use in sun Do NOT use on hot surface NEVER spray directly on glass. Use with caution, buff in and off instantly and neutralize. ※ Acidic solution - wear disposable gloves while working to avoid possible skin irritation. ※ Test in an inconspicuous place of any new material before using elsewhere ※ Do Not Ingest ※ Keep out of reach of children Do not spray in eyes - Wear eye protection to be safe May affect windscreen/window coatings and traditional sealants and waxes The IPA Glen mentioned should definitely work.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles. |
12-27-2016, 05:24 PM | #7 | |
See the the description & instructions also pulled from CarPro USA's website If left unattended, water spotting can cause permanent damage to the most resilient of vehicle surfaces, including automotive clearcoat, brightwork trim, and glass! First, wash and dry the vehicle to remove any surface grime or contaminants that could interfere with the performance of Spotless. Ensure that the vehicle is parked in the shade, and that the surface to be treated is cool to the touch. Start by shaking the bottle to integrate the active ingredients before spraying Spotless directly onto the surface, and working the product in thoroughly one panel at a time with a CarPro Applicator Sponge. Immediately wipe off the remaining product residue with a soft Microfiber Towel, and rinse the surface thoroughly to neutralize the solution. Dry and inspect the surface, and repeat if any mineral deposits remain. If etching has occurred, polish the surface with CarPro Reflect for painted finishes, or CeriGlass for glass before applying either Reload or Hydro2 for protection against future damage. |
