![]() Drives: 2017 Camaro SS Convertible 50th Join Date: Nov 2016
Jacking Points and Pucks
Hey guys - I am new to the forum having just bought my 50th Convertible SS this weekend. I have owned a C6 before and I remember using jacking pucks to lift her. Are these available and/or necessary for the 6th Gen Camaro? I have not found the correct jacking points in the manual - though I might have missed it somewhere in the 350 pages lol.
Interested in your thoughts and if someone has a picture of the jacking points. Thanks in advance! |
![]() Drives: 2016 2SS Camaro Join Date: Feb 2016
2SS - Summit White - MRC - NPP
Thanks. Good video but it did leave me with some concerns. It appears that the jack stands are being placed across the pinch welds. Is that correct? If so, I have seen way too many of those bend to do that. Or am I just not seeing it correctly?
Also, for four point lifts, where is are the appropriate jacking locations? Are those the pinch welds shown in the picture as well, or is it lifted from the subframe somewhere? |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: S O L D Join Date: Aug 2016
These are GREAT video's to use for reference. I must have watched them 10+ times. The only difference I found on my 2017 2SS Convertible, are the pinch welds at the front. You will notice on the video there are two "distinct" pinch welds. On my car there was only one (the forward one). However, you can access the other one right behind it - it just doesn't have the "cut out" shown in the video. I HIGHLY recommend the ZL1 Add On Pinch Weld Magnetic Jack Pad. It was WELL WORTH the $$........ I purchased the same hydraulic lift, and used 4 X 3 ton jack stands.
Yes, the jack stands were placed under the pinch welds. I did this 3 weeks ago, and no problems at all.......
Club F1FTY
2017 2SS 50th Anniversary Convertible Borla S-Type exhaust NPP| GM CAI | Color matched GM side skirts | Color matched 3rd brake light | Big Worm Graphics smoked out tail lights & rear reflectors | Oracle ghosted side markers | LED License plate bulbs | Door striker covers | Jam handle | Engine emblems from RiverCity Creations | 50th Center Console | Black bow ties | Hawk Performance ceramic brake pads | ZL1 Start button | CQuartz ceramic paint finish | Novistretch bra | S O L D |
Thanks Mike - Nice car - just bough the same one this weekend
. So how do you access the rear pinch weld if there is no cutout for it? admittedly I am not home to just go out and take a look underneath. I assume you jacked from the rear point if you put the jackstand on the front weld - correct? Also - have you had to take yours in yet to the dealer? SHOULD they have pads for jacking it? I ask because I was almost tempted to buy a set of the ZL1 Add-on Jack Pads in case I ever have to take it in - they can use all four... Thoughts? |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
On the convertible, I use the exposed pinch weld for the jack, with the jack puck, and put the stands under the other cut out where the cross brace is bolted on. Holds good with no bending that I can see.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers, Mamo Throttle Body Delivered: 08/15/2016 #TeamBeckyD |
#7 |
Thanks toro1966...... PM sent..... Oh, and you only require ONE of the ZL1 Jack pads........
Club F1FTY
#8 | |
Club F1FTY
#9 | |
![]() Drives: '23 LT Vert M6'16 Hyper 2SS Vert MT Join Date: Sep 2016
cheers, Joel |
#10 |
Sure, why not?
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon Join Date: Mar 2015
Pardon my ignorance, but how do the jack stands not bend the pinch welds?
#11 | |
Lethal Camaro
Drives: 16 2SS, 71 Std, Suburban RTS Join Date: Jun 2013
In the instance of the Jack stand, your setting the weight on the stand, with a jack your pushing the car up and putting pressure that can and will cause the pinch welds to flex.
#12 | |
Lethal Camaro
You should use the pinch welds as well. You can use other areas under the car, but most of it is soft aluminum and it can cave in or cause damage. Its a risk you take on some of the body points.
#13 | |
Sure, why not?
![]() So, you're saying that the pinch welds do rest directly on the jack stands, but that there is less force being exerted on them, since the jack stand is not moving/lifting the car, and that having pinch welds merely resting on jack stands does not exert enough force to bend/damage the pinch welds?
#14 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 2.0T RS Join Date: Jul 2016
You can always make your own pinch weld adapter/ Jack puck yourself also... I used these pucks i made myself (set of 5 didn't even cost $15 Cdn.) and used Sledgehammer70's locations to lift the car (front pinch welds: jack and support; rear pinch welds for support and the indicated brace to lift both sides of the rear at once)
Works like a charm, car has been in the air at least 6 times with zero damage (pucks also stay put on the pinch welds while positioning the jack) |
