11-07-2016, 05:44 PM | #1 |
Drives: 2017 Camaro 1LT HBM Join Date: Sep 2016
Adding LED tail lights to 2017 1LT non-RS
Assuming by now someone here has done this conversion, what adaptor/wiring harness is required to make it work? I am sifting through the vendors here in te meantime.
Thanks for any and all help. |
11-07-2016, 06:18 PM | #2 | |
Drives: 2016 Hyper Blue Metallic 1SS M6 NPP Join Date: Jan 2016
http://www.gen5diy.com/Gen6-Camaro-N..._description=1
2016 Hyper Blue Metallic 1SS M6 with body color hood vents, Silver broken 5 spoke wheels, NPP dual exhaust, Dark Night Interior Spectrum Lighting, Illuminated door sills plates. Upgrades include: Roto-Fab intake, Mishimoto catch can, MBRP cat-back Race exhaust, TSP 1 7/8 headers, EFI E85 Flex Fuel, MRR M017 graphite wheels with Nitto N555 G2 tires, Goodridge stainless steel brake lines, Powder coated Brembo calipers, BMR suspension, Eibach sport springs, Emblempros fender badges Order ID: TDHQMS 1100 on 01/07/2016 at Penske Chevrolet 6000 on 02/23/2016 Delivered to customer |
11-08-2016, 08:44 AM | #3 |
What is the difference between the LED tail lights of an RS Camaro (1LT/2LT) and a SS? As I said above I want to put LED taillights in a 1 LT non-RS but I need to make sure I understand what can and can not be easily done and whether there is a difference in the two LED sets.
11-08-2016, 09:34 AM | #4 | ||
Drives: Camaro Coupé 2.0T AT8 (EU version) Join Date: Mar 2016
Hi nfboy!,
See you!!, Eos |
03-29-2017, 06:34 PM | #5 |
Drives: 2016 Camaro 1LT Join Date: Apr 2016
Bumping this post for additional info. I have the 1lt and want to add the clear tail lights. I know i need them and the harness from gen5diy. What about the bulb itself? I need to buy the LED for each tail light, correct? If so, does anyone have a part number?
03-30-2017, 03:08 AM | #6 | |
Drives: 2017 2SS/M6 W/MRC & NPP Join Date: Nov 2016
If you want to upgrade those to LED's, Gen5diy sells a harness/resistor for that too (as does phastek)... Otherwise, The LED running lights and brake lights are built into the tail lights. |
03-30-2017, 06:04 AM | #7 | |
Hi pjz1082!,
The only bulb that will not be made of LEDs will remain the reverse light, but it is possible to change them (if you don't like their look as OEM). So, if you want the RS/SS original LED look, simply go for the LED assembly (and the harness, of course). See you!!, Eos |
03-30-2017, 12:47 PM | #8 |
Thanks guys! Appreciate the feedback!
