11-07-2016, 05:26 PM | #1 |
Drives: 2015 Red Rock ZL1 Join Date: Dec 2014
Garage lift
I recently went to a friends man cave, 4 Corvettes, and he keeps one on a lift with one parked under it... my wife should have never let me go there do any of y'all (yes I'm in the south) keep your ZL1 on a lift and if so do you recommend a particular brand and/or style? I've been looking at the 8000lb lifts and they're remarkably affordable... thanks for your input and any and all pictures will be drooled over hahaha
Alex
2015 Red Rock ZL1 Panama City Beach, FL |
11-07-2016, 05:28 PM | #2 |
Sorry... old man and technology hahaha
Can someone delete my dual post?
Alex
11-07-2016, 05:55 PM | #3 | |
Drives: 2013-ZL1, 69-Z28, 71-CHEVELLE SS Join Date: Oct 2016
I have a revolution lift from rotary http://www.revolutionlift.com/default.aspx |
11-07-2016, 06:18 PM | #4 |
Buddy of mine has a 4 post and he swaps his Grand Sport and ZR1 on it. It's a great plan plus it helps for maintenance.
Wish I had the garage height for it. |
11-08-2016, 07:04 AM | #5 |
Drives: 2010 2SS-RS, IOM, M6 Join Date: Mar 2012
I know i dont have a ZL1 but the lift was well worth it when needing to work on the Camaro or my Truck.
2SS/RS, Inferno Orange, 6sp, Eibach lowering springs, Eibach adjustable sway bar, Exhaust 2.5" dumps before axle, New ERA OTR intake, TSP LS3 225/230 .617/.612 on a 112LSA cam,
Rocker arm trunion kit, ported/polished heads, JRE Tune, ARH Headers, G-Force Axles, 3.91 Gears, Eaton Detroit Truetrac /w Billet Caps, MGW Shifter, DynoTech Driveshaft, E2X Catch Can . |
11-08-2016, 07:54 AM | #6 |
That's really nice!!!
Alex
11-08-2016, 08:22 AM | #7 |
Thx its great, I also got the extra 4500lb hydraulic jack that rolls between the ramps very useful for jacking up the car for removing tires or other work have used it a lot.
11-08-2016, 08:23 AM | #8 |
Drives: 2015 ZL1, Red Hot A6 Join Date: Aug 2016
Yup, lift is the way to go! Here's 1200Hp in a nice stack. The '69 chevelle has a LS3 418 stroker with big heads and cam making 630HP.
2015 Red Hot ZL1, Rotofab, Kooks LT's, 10" lower, ID850's, JMS BAP, BTR stage 3 torque cam, meth injection, self tuned with HPtuners
1969 Chevelle, 418 LS3, Ridetech suspension |
11-08-2016, 08:30 AM | #9 |
Very nice setup and always liked the older Chevelles...
11-08-2016, 09:29 AM | #10 |
Drives: 2020 Orange Crush 1SS/1LE Join Date: Jun 2016
As the one copoz28 posted, Bendpak without a doubt.
11-08-2016, 09:31 AM | #11 |
Mine is a Direct Lift I believe. It's commercial rated and everything so it would be legal in a commercial shop but it is much cheaper than a bend pac....fine for home hobby use but you may not want to be using it all day every day in a shop setting.
11-08-2016, 10:08 AM | #12 |
Drives: '16 Z06/Z07, '15 Z/28,1972 Stingray Join Date: Feb 2013
+1 for the Bend Pak!!
2015 Z/28 #642 Black Bad Ass
11-08-2016, 10:28 AM | #13 |
Drives: 2015commemorative vert 2SS Join Date: Oct 2013
I went with a 4 post version. I do basic maintenance, but not that often as my cars are newer. I went the atlas 9600lb, its big enough for my dually long bed truck too.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded 2015 commemorative vert 2ss |
11-08-2016, 04:28 PM | #14 |
Got the Atlas pro 8000. I've done engine and transmission removals with it. No issues with stability. Best gift that I've ever gotten.
No longer stock, but oooh so much more fun!
