Old 10-02-2016, 04:43 AM   #1
Hyper1SS
Hyper1SS's Avatar
Drives: 2016 Hyper Blue Metallic 1SS M6 NPP
Installation of the Illuminated Door Sill Plates
I have the 2SS Illuminated Door Sill Plates I will be installing on my 1SS soon. Here is the GM tech install info from my dealership.
2016 Hyper Blue Metallic 1SS M6 with body color hood vents, Silver broken 5 spoke wheels, NPP dual exhaust, Dark Night Interior Spectrum Lighting, Illuminated door sills plates.
Upgrades include: Roto-Fab intake, Mishimoto catch can, MBRP cat-back Race exhaust, TSP 1 7/8 headers, EFI E85 Flex Fuel, MRR M017 graphite wheels with Nitto N555 G2 tires, Goodridge stainless steel brake lines, Powder coated Brembo calipers, BMR suspension, Eibach sport springs, Emblempros fender badges
Order ID: TDHQMS
1100 on 01/07/2016 at Penske Chevrolet
6000 on 02/23/2016 Delivered to customer
Hyper1SS is offline   Reply With Quote
Old 10-02-2016, 04:59 AM   #2
Hyper1SS
Hyper1SS's Avatar
Here is a couple pictures of what you get in the package.
Order ID: TDHQMS
Old 10-02-2016, 03:55 PM   #3
Hyper1SS
Hyper1SS's Avatar
Before
Order ID: TDHQMS
Old 10-02-2016, 03:58 PM   #4
Hyper1SS
Hyper1SS's Avatar
Inner trim panel removed
Order ID: TDHQMS
Old 10-02-2016, 04:03 PM   #5
Hyper1SS
Hyper1SS's Avatar
Non illuminated stock 1SS door sill plate removed
Order ID: TDHQMS
Old 10-02-2016, 04:18 PM   #6
Hyper1SS
Hyper1SS's Avatar
Double sided tape removed on the bottom side edge. They give you 2 alcohol pads to clean that area after so that installing the new illuminated sill plate with it's double sided tape to stick in the same location.
Order ID: TDHQMS
Old 10-02-2016, 04:30 PM   #7
Hyper1SS
Hyper1SS's Avatar
Was time to install the new illuminated sill plate. Make sure you pull up the weather stripping in the whole plate area. I pulled the backing off one corner of the double sided tape to help pull it off once sill was in place. Also I put the outer clips in first and than rolled the back edge down and into place to help seat the rubber edge against the car. Make sure the sill wire is left in the center of the sill.
Order ID: TDHQMS
Old 10-02-2016, 04:34 PM   #8
Hyper1SS
Hyper1SS's Avatar
You have to run the wire from the illuminated door sills plate under the weather stripping to the inside. After the whole system is in than make sure to push the weather stripping back down into place.
Order ID: TDHQMS
Old 10-02-2016, 04:39 PM   #9
Hyper1SS
Hyper1SS's Avatar
Now that the illuminated door sills plate is in place run the wire behind the carpet towards the front and plug into the wire that you had to run under the dash from drivers side to passengers side.
Order ID: TDHQMS
Old 10-02-2016, 04:42 PM   #10
Hyper1SS
Hyper1SS's Avatar
On the passenger side pull the carpet back and find a ground bolt and install your ground wire.
Order ID: TDHQMS
Old 10-02-2016, 04:47 PM   #11
Hyper1SS
Hyper1SS's Avatar
On the drivers side find the BCM under the dash. The first connector which is gray unplug it. Looking at it the gray wire on the top left in hole 1 after pulling the black wrapping back cut the wire. Give yourself enough room next to the connector to be able to connect your supplied harness and crimp it to that wire.
Order ID: TDHQMS
Old 10-02-2016, 04:50 PM   #12
Hyper1SS
Hyper1SS's Avatar
I forgot to say before I installed the new illuminated door sill plates I left everything loose and laying on the floor boards with all wires connected and tested the sills to make sure everything worked before installing everything permanently.
Order ID: TDHQMS
Old 10-02-2016, 04:55 PM   #13
Hyper1SS
Hyper1SS's Avatar
Once everything is installed I used the wire ties that GM supplied to hide and hold all of my wires up under the dash on both side. And here is a finished picture. Love them!!
Order ID: TDHQMS
Old 10-02-2016, 06:53 PM   #14
GOMD
GOMD's Avatar
Drives: 2017 Camaro 1SS, 2023 Sierra
Let me be the first to say, awesome write up. Thanks. I will be looking into this next yr when I get my 1SS.
GOMD is offline   Reply With Quote
