09-13-2016, 11:34 PM | #1 |
Differential Noise and power train warranty
Hello All,
I recently went to a local Chevrolet dealership to discuss a howling noise from the diff on my 2012 Camaro 5. I have had this diff replaced before, the first replacement was due to a faulty bearing within the actual housing itself with fragments of metal eating away at the gear causing the gear assembly to fail I now have the same issue, roughly 25K miles later. I visited the dealership, and it seemed as though they proceeded to advise me on what part I would be liable for, keep in mind, I have not tracked, modified, or supercharged this vehicle. I would think that the 100K warranty would apply in this situation. Anyone have any experience with this issue once, or more than once? Thanks In Advance Nino |
09-18-2016, 01:15 PM | #2 |
it is certainly a part of the powertrain,i would think they would be on the hook for whatever it takes to make it right.
09-20-2016, 08:07 AM | #3 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
Tell them, let me advise you what part of the warranty will be covering this...all of it. Any questions, that's not my fkng problem either.
09-20-2016, 03:28 PM | #4 |
not sure that would be the way to go about it.tell them you are going to speak to the zone representative or contact chevy service,then explain how this dealer is treating you.
09-23-2016, 05:54 PM | #5 |
Working with GM Customer Service
Wanted to post an update, I'm currently working with GM customer service on getting this to a dealership that will fix the issue, it happens to be the dealer that I bought the car from. Taking it over tomorrow AM, they will have a loaner car waiting.
The picture to the left as the Avatar is when I first bought the vehicle in 2012, before it started to rattle! GM Customer service has been very helpful. |
09-24-2016, 09:12 PM | #6 |
All unnecessary. The car came with a warranty book. Open it and show them where it is covered in black and white. They can call Chevy if they don't know how to read the warranty.
09-25-2016, 07:59 AM | #7 |
it sounded to me like the first dealer he went to wasnt being too cooperative.apparently he has found a good one now.
09-26-2016, 04:59 PM | #8 |
Tear down in progress at dealer, service manager said "sounds like a spun internal diff bearing race" we'll see what they say. Being this is the second issue that is bearing related, my expectation is that they honor the warranty and do what is in the best interest of the customer.
09-26-2016, 05:03 PM | #9 |
I've had a good experience with this dealer on both Camaro purchases aside from the mechanical issues, the first 2010 had an oil consumption issue, would burn through 3-4 quarts between oil changes, traded in the black 2010 L-99 for the 2012 M6 LS3. I have to say at this point given the previous mentioned issues, onto a Silverado Crew Cab!
09-27-2016, 11:06 AM | #10 |
My 12 ZL1 has the same problem...24 k miles still under the power train warranty.
GM told me no help but after a few calls was told that GM would pay half of the 500 bucks it cost to chand the lube 3 times and the figure 8 routine. GM also said it may or may not fix the problem but if this process did not fix it the PowertrIn warranty would like in and take care of anything else. I think the PT warranty should cover it all but I guess I'm lucky to get Out for a couple hundred dollars. If any of you need my work order number for ammo against GM let me know and you are welcome to it. |
10-08-2016, 01:54 PM | #11 |
Got car back today
Diff replaced, we'll see how this goes. I don't have enough space within the type field to describe the issues they found when the tear down took place. let's just say bad - really bad! Working with GM legal on buy back, they have all the service records relative to the issue, just need to wait and see what they come back with! More to follow.
10-08-2016, 02:59 PM | #12 | |
Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
10-08-2016, 08:06 PM | #13 |
I'm thinking that they did not, they replaced some seals, bearings the first two times, that tells me there was particles (metallic) still within the differential, if they would have replaced it the first time, this issue may not have occurred, the one they just replaced it with is still making a howling noise, we'll see how long this one lasts. If it persists, back to the shop it goes!
10-09-2016, 10:25 AM | #14 | |
