08-15-2016, 08:46 PM | #1 |
9 Year USMC Vet
Drives: 2014 1LT black on black Join Date: Nov 2015
HP gain and 0-60 question
Ok, so I've been on here since late November 2015.
I have a 20151LT Here's what I've done so far for performance uprades: K&N Typhoon intake Apex scoop with WW relocate Barton short throw shifter Vitesse throttle controller Glasspack mufflers and MagnaFlow resonated Xpipe Planned: 80mm throttle body Jacfab intake My questions are, what should I have gained in HP so far, and what is a realistic 0-60 time? I know I should get an Overkill tune and it's in the plans, but I'm hesitant about voiding my warranty. I'm not going to get the E85 tune when I get it either Thanks
A lot of stuff done so far to make it look better and be more fun to drive.....
08-15-2016, 08:51 PM | #2 |
Drives: 2017 ZL1 A10 Join Date: Sep 2014
260 hp
Current: 2017 ZL1 A10 previous: 2019 1SS A10 previous: '14 L99, CAI intake, vmax ported tb, e85 kit, stage 2 cnc heads, speed engineering long tubes, custom high flows, resonated x pipe, muffler delete, qtp cut outs, gpi ss3 vvt Cam, zl1 pump and injectors, fti triple disc, mayhem motorsports trans cooler and tune, ngk spark plugs +red msd wires, 3.91 gears. Past: '12 LFX, full bolt ons + E85, 302hp/267tq |
08-15-2016, 09:03 PM | #3 | |
9 Year USMC Vet
I still have the crappy stock 245's on it and now with the Barton, at least I don't miss the 1-2 shift.
08-15-2016, 09:13 PM | #4 |
9 Year USMC Vet
Ok, so what will I gain when I add the 80mm throttle body and the Jacfab intake?
08-15-2016, 09:18 PM | #5 |
9 Year USMC Vet
But with already having the VTC will it make a real difference adding the TB?
08-15-2016, 09:36 PM | #6 |
9 Year USMC Vet
Soooooooo.... it sounds like the next mod should be the intake and keep the VTC.
A dyno before and after the intake might provide some info that hasn't been provided yet? Hmmm...
08-15-2016, 09:58 PM | #7 |
9 Year USMC Vet
Cool, thanks..
I meant intake manifold. Looks like that will be next on the list for performance uogrades. If I add the spacer I need to ditch the BMR strut brace, right ?
08-16-2016, 03:06 AM | #8 |
Drives: 2015 RS camaro Join Date: May 2016
You have to be realistic here. It's a naturally aspirated gas 217 in v6
08-16-2016, 04:55 AM | #9 |
Drives: 2015 1LS Red V6 Join Date: Aug 2015
Will is working on some tuning fixes for that...i have been testing them for about the last month...dare I say...touchy?
Sponsors:
Overkill Motorsport BCS Auto JacFab Machining APDEG Dream Gear Mobile Audio Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet 5th Gen V6 Performance Facebook Group |
08-16-2016, 05:41 AM | #10 |
The strut brace fitting isn't effected by it at all. Your engine cover will be a tight fit
