Old 07-07-2016, 09:40 AM   #1
Bobfly
OspreyTech
Bobfly's Avatar
How Fat Can I Go?
What is the widest tire that will fit in the wheel well without interference or rubbing issues on the rear? I know about the rubbing issues with 305/35 series tires on 11 inch rims due to tire height issues on the drivers side. Aside from that and with a 30 series tire, how wide can a person go? Has anyone tried 315's or 325's on the back?
2SS Nightfall Grey Metallic w/Ash Grey Interior, Silver Rally Stripes, 6M, MRC, DPP, Nav, Sunroof & Black Bowties
Bobfly is offline   Reply With Quote
Old 07-07-2016, 10:18 AM   #2
jaysonstuart
jaysonstuart's Avatar
Fattest I've seen mentioned on here is 305's.
jaysonstuart is offline   Reply With Quote
Old 07-07-2016, 10:35 AM   #3
ajp
50th Anniversary Vert
ajp's Avatar
Drives: Camaro 2017 50th Anniversary
I had to get 305/30s, problem is the car looks like a 4x4.
ajp is offline   Reply With Quote
Old 07-07-2016, 10:41 AM   #4
Richard0nee
Richard0nee's Avatar
Drives: 2016 SS M6, NPP
Why is your front so high? Also, getting larger tires shouldn't raise the ride height. Why did your car get higher?
Richard0nee is offline   Reply With Quote
Old 07-07-2016, 10:44 AM   #5
ajp
ajp's Avatar
No idea, maybe the car has to settle.
the 315/35s from my 5th gen were rubbing, dealer said securing the wire harness would would the warranty (whatever that means), so my only choice was to replace the tires with 305/30s, as you can see, the wheel well gap is huge.
Old 07-07-2016, 10:50 AM   #6
Richard0nee
Well if your car just got down from a life sure it'll look higher and a simple drive around the block the suspension will settle down to it's original height.
Putting the 305's in should decrease the wheel gap due to the bigger tire if anything.
Anymore pics of the whole car with showing the stance? This is puzzling..
Dealer don't want you to move/mess with the wire harness thus the void warranty issue.
Old 07-07-2016, 11:21 AM   #7
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
i have 295/35/20 in the rear
Old 07-07-2016, 11:53 AM   #8
Bobfly
OspreyTech
Bobfly's Avatar
I think it's because you went with a 30 instead of a 35. Shorter tire.
Old 07-07-2016, 11:55 AM   #9
ajp
ajp's Avatar
In hindsight, I should have gone 295/35.
Old 07-07-2016, 01:03 PM   #10
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
315/325 would need low profile and an offset that would push the wheel out quite a bit.
some people like that look, but I think it looks... weird.
There is a 12" set-up out but they still use 305's. Fender issues limit the width. 325 might work with 30 series or 25 series
