Old 06-29-2016, 11:45 AM   #1
kmarshall2121
kmarshall2121's Avatar
Drives: 2012 45th Anniversary Edition
Engine or Motor?
Discussions between many of my friends: is the power house under your hood referred to as an 'engine' or a 'motor'? I have used both, however, some would say the only 'motor' under your hood operates the wipers... thoughts??
kmarshall2121 is offline   Reply With Quote
Old 06-29-2016, 11:48 AM   #2
dantemcc
Drives: 2017 1SS 1LE
LoL
dantemcc is offline   Reply With Quote
Old 06-29-2016, 11:48 AM   #3
Thor142
Thor142's Avatar
Drives: 2014 2LS (traded in) 2015 1SS 1LE
A motor is electric is uses currents and magnets to turn. An engine uses the expansion of gases to turn.
Thor142 is offline   Reply With Quote
Old 06-29-2016, 11:50 AM   #4
Repooh
Certified: Slow
Repooh's Avatar
Drives: 2014 Ashen Grey 1SS/RS LS3
Engine for me. It's the same thing as "e-brake" vs "parking brake". I use parking brake but I know what people mean when they say e-brake.
Red Bull gives you wiiings.
2014 Ashen Grey Camaro 1SS/RS LS3
Winter Vehicle- 2002 Subaru Impreza WRX
Repooh is offline   Reply With Quote
Old 06-29-2016, 12:04 PM   #5
Kopterman
Kopterman's Avatar
Drives: 2014 Bright Yellow 2SS/RS
Well, not really the same thing.
E-brake is referring to "Emergency Brake" not Electric Brake..
Kopterman is offline   Reply With Quote
Old 06-29-2016, 12:07 PM   #6
sherob
sherob's Avatar
Drives: 2015 SW 1SS/RS 1LE
... "E-Brake" doesn't even register... hand brake, sure... parking brake, sure.
“The Eagles and the Captain and Tennille ruled the airwaves, and we were the answer to it.” - Joey Ramone
http://www.camaro5.com/forums/picture.php?albumid=17325&pictureid=134228
sherob is offline   Reply With Quote
Old 06-29-2016, 12:08 PM   #7
Repooh
Certified: Slow
Repooh's Avatar
Sorry I wasnt clear haha...I know people mean emergency brake (e-brake), I'm saying when people ask what motor my car has I know they mean engine.
Old 06-29-2016, 12:09 PM   #8
pbeyer2010
pbeyer2010's Avatar
Drives: 2015 Camaro 2SS
To each their own however i do believe "engine" is the appropriate term and a "motor" typically refers to an electrical drive system.
pbeyer2010 is offline   Reply With Quote
Old 06-29-2016, 12:18 PM   #9
ron123
ron123's Avatar
Drives: 2014 2SS/RS
During the last oil change I put Mobil 1 MOTOR OIL in the ENGINE ... ;-)
Ron
2014 2SS/RS, Z28 CAI and High Wing Spoiler, ZL1 5.1:1 Ratio Short-Throw Shifter, ZL1 Pedals, ZL1 splash guards, NPP Dual-mode quad tip exhaust, Z28 strut tower brace, Camaro LED Cup-holders with footwell Lighting option, Leather visors, and Leather E-brake boot. Chevy dealer sponsored 67 retro SS nose stripe package.
ron123 is offline   Reply With Quote
Old 06-29-2016, 12:22 PM   #10
sherob
sherob's Avatar
My build sheet lists... ENGINE, 6.2L V8 W/ SFI MAH
Old 06-29-2016, 12:24 PM   #11
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Send a message via AIM to SSE 4 2SS Send a message via Yahoo to SSE 4 2SS
This has been played out many times.
Yes by original definitions a motor referred to an electrically power item. An engine is fuel powered and an internal combustion object.. In most cases... As we also have steam engines... Symantics arguments can be made either way...
However, the generally accepted reference is that in this case it's interchangeable. After all, there is General Motors, the Ford Motor Company, Bayerisch Motoren Werke, or Bavarian Motor Factory, BMW... Etc...
When I was in the Fire Department we had engineers... Those that operated the apparatus.... Right up until we got an anally obsessed City Manager that stated the only Engineer has a college degree... (Yes his ego was way larger than his capability) and he mandated that the operators be referred to as drivers, not engineers... So we countered with, " what about the guys that operate trains.
I am an engineer by trade (Subsea Engineer) and I use the term interchangeably quite often...
Look at it this way, what is a Turbo? Some will say it's a compressor, and it is, but when originally designed for use in aircraft it was and technically still is a turbo supercharger... Yet I would be derided for referring to my car as twin supercharged... In this day, the shortened version, Turbo, is the accepted term...
If the car feels like it is on rails, you are probably driving too slow. -Ross Bentley
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
“If everything seems under control, you're just not going fast enough.” Mario Andretti
If you can turn, you ain't going fast enough...
SSE 4 2SS is offline   Reply With Quote
Old 06-29-2016, 01:03 PM   #12
Flashpoint135
Flashpoint135's Avatar
Drives: 2016 SS
I'd rather be called a MotorHead than an Enginehead. Otherwise IDC.
Flashpoint135 is offline   Reply With Quote
Old 06-29-2016, 01:06 PM   #13
Juiced1
Drives: 2012 2SS CAMARO 45th
Engine is the correct term but I think we all call it a motor most of the time.
Juiced1 is offline   Reply With Quote
Old 06-29-2016, 01:21 PM   #14
Dmpsix
Dmpsix's Avatar
Drives: Black L99 2SS/RS
What about a v6 motor vs a v8 engine? ?
Dmpsix is offline   Reply With Quote
