06-26-2016, 03:09 PM | #1 | |
Drives: camaro 4th gen Join Date: Nov 2013
2017 ZL1 is Getting Line Lock!
check this link from autoblog
http://www.autoblog.com/2016/06/26/2...-burnout-mode/ Quote:
The function is activated through the launch control menu when the car is in Track mode and the transmission is in Drive or first gear. Once the line is activated in lock in the instrument cluster screen, the driver presses 80 pounds of pressure on the brake pedal. A status bar in the multifunction screen show a readout up to 100 percent. Then, mash the gas and light up the tires. The feature is intended for prepping for a drag strip run. But wait, there's more. Press both center buttons on the steering wheel pads - cruise control on the left and select on the right - and a rolling burnout kicks in. Line lock works for 15 seconds before cutting throttle. |
06-26-2016, 03:12 PM | #2 |
HAMMER PILOT
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado Join Date: Nov 2011
Sweet!
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
06-26-2016, 07:16 PM | #3 |
Use the Force
It does not look like line lock to me. You can see a small movement forward before it takes a set and does the burn out. A line lock would have prevented that slight movement forward.
Walk softly, carry a light saber and drive a ZL1!
06-26-2016, 07:34 PM | #4 |
Hyper Blue 2016 Camaro 2S
Drives: 16 Hyper Blue2SS NPP MagRide 6M NAV Join Date: Apr 2016
Ya if I were a betting man I would say it's not going to have linelock. I've messed with the C7Z06 a ton and I haven't found it in there either.
While it would be neat to have, it's not really needed unless you plan on doing a lot of serious tracking/burnouts. |
06-26-2016, 08:42 PM | #5 |
Drives: 2018 ZL1 6M, Silverado High Country Join Date: Oct 2008
Al O himself said it will have custom launch control with line lock.
Current Vehicles - 2018 ZL1 Red Hot 6 spd manual, Carbon Hood, Sunroof 2019 Silverado High Country, Daily Driver |
06-26-2016, 09:44 PM | #6 |
This was mentioned in Al O. Facebook post and details in Today's autoblog.....
'17 ZO6 - Watkins Gray Metallic
'17 911 4GTS - Carmine Red '17 Bolt - Hyper Blue '02 SS - 35th Anniversary Ed. - 645 miles '89 IROC Z - 2500 miles '73 Z28 - Survivor 36k miles '69 RS/SS 496 - 631 HP 618 TQ '67 SS - Alum. 406 under construction |
06-26-2016, 11:31 PM | #7 | |
Drives: Charger Hellcat Join Date: Apr 2016
When I was waiting for my Hellcat I loved watching video reviews, but honestly the giggling burnouts got a bit old after a while. |
06-27-2016, 09:38 AM | #8 | |
Drives: '16 2SS / '05 SRT10 Ram / '65 bu Join Date: Dec 2015
Also, 15 seconds seems like a long time before throttle is cut ??!!??
06-27-2016, 10:12 AM | #9 |
Drives: 2017 Ford F250, 2019 Lincoln Navi Join Date: Apr 2016
If that really is the case, it's going to be awesome. Quite possibly one of the best, if not the best ways ever incorporated in a car. Can't wait to know for sure...
Instagram: MattZ_L1 Vengeance Racing Built
06-28-2016, 08:12 AM | #10 |
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
2017 ZL1 getting Line Locks!
Sweet! Hopefully it trickles down to the standard SS!
06-28-2016, 08:48 AM | #11 |
Drives: 2SS convertible, black,black Join Date: Apr 2016
Thank you for the link.. After that, there were some great other news articles and videos. I liked the "guess" that a new GM Halo car ( mid engine) won't be a Corvette and maybe a Caddy
A little known fact. Women with extra pounds, tend to live longer than men who mention it.
06-28-2016, 08:53 AM | #12 |
Drives: 4 wheels Join Date: Dec 2009
Confused how this works on a manual... You can't push the brake 80% then mash the gas as its described, while still holding down the brake. You need to switch your feet.
So how would that workout? |
06-28-2016, 09:21 AM | #13 |
I used to be Dragoneye...
This is......so. Freaking. Cool!
06-28-2016, 12:15 PM | #14 |
The way it works on Mustangs with a manual is that you start by requesting line lock with the steering wheel controls. Then you have to have your foot firmly on the brake pedal for a few seconds. After that you'll see confirmation on the dash display that line lock is engaged, so you can release the brake pedal and move your foot to the clutch to prepare for the burnout.
