Old 06-03-2016, 10:02 PM   #1
mjwill25
Drives: 2016 Black 2 SS
Stock V8 NPP Exhaust For Sale
I got the Borla ATAK rear section so have my stock NPP rear section available for sale, only 640 miles on the exhaust. $200, local pick up only.
2016 2SS Black on Black, NPP, MRC with 6 speed, ARH Catted LT Headers, AWE Touring Exhaust, RotoFab CAI, Soler Performance TB and TC, GPI Ported LT2 IM, Pray Ported Heads, Pray Custom Grind Stage 2 Cam, DSC v2, BMR STB019H, Stance SF10 in Brushed Dual Gunmetal, Black Bowties, Black SEMA Grille, Smoked Tail Lights, Oracle Ghosted Side Markers
mjwill25 is offline   Reply With Quote
Old 06-08-2016, 06:02 PM   #2
2drstunner
Drives: 2016 Chevy Camaro SS
Does it bolt up to the stock none NPP exhaust? Also I believe but I'm not positive that the openings on the black piece around the exhaust is smaller on the cars without NPP exhaust
2drstunner is offline   Reply With Quote
Old 06-08-2016, 09:46 PM   #3
Alpha1BC
Alpha1BC's Avatar
Drives: 2017 1SS 1LE
From my research, it looks like an NPP muffler can bolt on to a non-NPP exhaust if welding or using clamps. No bolted joints for just axle back, need to cut and re-attach. However, there's a little more to it than just bolting it up.
1) The wiring harness for the NPP actuators isn't on non-NPP cars, or at least I can't find it on mine). Would need to wire up your own controller or switch for manual control (easier), or figure out how to wire and reprogram the controllers that control the NPP from the factory (not easy and probably not possible without help from a dealer).
2) There are other valves in the non-NPP exhaust that I haven't seen on NPP systems. They're located about 2 feet before the muffler on the mid-pipe. Not 100% sure what those valves are or how they're controlled, but they'll most likely change the sound.
3) You are correct, the rear lower fascia would need to be replaced/cut to allow room for the dual tips on each side instead of the stock single tips.
4) I'm guessing that this isn't a huge concern, but making this change will also void warranties (I'd be really surprised if it didn't, at least).
2017 SS 1LE.
Alpha1BC is offline   Reply With Quote
Old 06-08-2016, 10:03 PM   #4
BadBillyJack
Drives: 2016 2SS Camaro
The valves are defaulted to the open position. So if someone was buying this for looks and the sound of the NPP exhaust with open valves the only other thing they would need is the rear bumper lower valance, and a new clamp and gasket. Considering GM has this exhaust at list price of ~$2500. I'd say you are basically giving it away. Especially since the "core charge" on the catalytic converters is $200.
2016 2SS Nightfall, A8, NPP, MRC, Jet Black leather.
Originally Posted by 20171LE View Post
The fact remains, the Camaro designers have another fail in not transferring the clothes hanger from the ATS to the Camaro.
I, and every other Camaro owner that hangs clothes in their cars, need a solution.
BadBillyJack is offline   Reply With Quote
Old 06-16-2016, 07:36 AM   #5
2drstunner
pics? Curious where it was cut
Old 06-16-2016, 07:44 AM   #6
Lucely Engineered
Lucely Engineered's Avatar
Drives: 2016 Camaro 2SS M6
Does it have the valves or did you use those on the borla?
Lucely Engineered is offline   Reply With Quote
Old 06-16-2016, 07:50 AM   #7
mjwill25
I will try to get by the shop to get some pics in the next day or two.
Valves are still there, the Borla system comes with their own valves so don't need to reuse the stock ones.
Old 07-28-2016, 05:18 AM   #8
2drstunner
Pm sent!
Old 07-28-2016, 06:01 AM   #9
HyperBlueX2
The electronic actuators stay with the car wiring harness....
Old 08-02-2016, 09:31 AM   #10
mjwill25
Sorry for not replying in a while, the exhaust was cut just before the suitcase:
Old 08-09-2016, 07:35 AM   #11
2drstunner
Pm sent
Old 08-10-2016, 06:30 PM   #12
mjwill25
Exhaust has been sold.
