Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum
Old 05-13-2016, 10:25 PM   #1
Harley01
Drives: 2015 Camaro ZL1 (red hot)
Aeroforce Gauges (must read!!)
Hey guys,
So I had a OBD2 splitter cable and when I hooked my hp tuner to look at some parameters the interceptor dual gauges went off. Looks like they're fried!! They will not power up at all now. Looks like they are damaged, I contacted aeroforce to find out if they are repairable or if I have to order new? No response yet. These were the dual scan model CN202. Expensive lesson, don't make the same mistake I did!!
Harley01 is offline   Reply With Quote
Old 05-13-2016, 11:23 PM   #2
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Drives: 2010 Camaro SS
You split cabled the CAN BUS?
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray
480 RWHP 452 RWTQ + Nitrous Express 150 Shot
LSX Camaro is offline   Reply With Quote
Old 05-14-2016, 06:45 AM   #3
Harley01
Correct! Thought it would keep me from having to un-plug the aeroforce gauges every time I needed the OBD2 port. I also have a car lock device that uses that port. This sucks, hope their repairable!!
Old 05-14-2016, 09:31 AM   #4
Azzkker
Azzkker's Avatar
Drives: 2013 AGM ZL1, 99 z28, 89 iroc-z
Did you check to make sure the power at the obd dlc is still present? The gauges wont work if that power source has blown its fuse.
Azzkker is offline   Reply With Quote
Old 05-14-2016, 09:56 AM   #5
I'm thinking about getting rid of Aeroforce and just going to hard wire gauges that keeps the OBDII free for HP Tuners. I'm only watching AFR and IAT anyway.
Old 05-14-2016, 10:52 AM   #6
Harley01
Very good suggestion. I'll do that. Thanks
Old 05-14-2016, 11:04 AM   #7
derek1387
Drives: 2015 1LS Red V6
Yup. Exact reason i didnt do the Aeroforce.
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Dream Gear Mobile Audio
Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet
5th Gen V6 Performance Facebook Group
derek1387 is offline   Reply With Quote
Old 05-14-2016, 11:28 AM   #8
... or just hook up HP Tuners and see if it works.
