05-11-2016, 02:27 PM | #1 |
cold air
I purchased a SPECTRE CAI awhile back and for the life of me I can't see the advantage to buying a high dollar unit other than maybe looks. I have put this unit through some hard throttle and high speed runs and it performs just fine.
05-11-2016, 02:31 PM | #2 |
This is why
https://m.youtube.com/watch?v=YdJtOecMrpA SLP supercharged 2013 SS/RS 1LE VR Full front half protected by Xpel PPF Instagram:@Failshift 565hp/560tq @8.6psi 1LE Owners Group: https://www.facebook.com/groups/559684050767758/ |
05-11-2016, 02:34 PM | #3 | |
Drives: 2014 Red Hot LS3 Join Date: Oct 2014
05-11-2016, 02:49 PM | #4 |
I'm a CAI, Inc. man myself. Don't want any plastic intake tubes on my car. Also, with enclose and insulated air box and the Apex air scoop addition, there is an absolute minimum amount of leakage and engine bay (super hot) air being fed to the engine. The cooler the air the better.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
05-11-2016, 02:56 PM | #5 | |
What he said. Plus they just look sexy |
05-11-2016, 03:20 PM | #6 |
Drives: Chevys at the limit Join Date: Nov 2010
05-11-2016, 03:22 PM | #7 | |
El Duderino
I bowl. Drive around. The occasional acid flashback.
05-11-2016, 03:47 PM | #8 |
Drives: 2012 SS/RS MN6 Join Date: Mar 2016
That's a heck of a bend
05-11-2016, 03:49 PM | #9 | |
Drives: 2014 Chevy Camaro SS Join Date: Dec 2014
That's my setup, CAI Inc, Apex race scoop mod and ported TB. YES you can tell the difference. |
05-12-2016, 03:51 PM | #10 |
+2... it doesn't get any better.
05-16-2016, 09:29 AM | #11 |
Drives: 2011 camaro IOM Join Date: Mar 2011
mudwheel57, i couldn't agree with you more, i have the same intake for over 4 years now and never had a problem. but if you don't buy well known name brand products someone here will give you a hard time and be negative about it.
05-16-2016, 02:34 PM | #12 |
Drives: 2010 Camaro RS 2LT Join Date: Apr 2016
I had a Spectre on a past car and the build quality was so poor that I had to get rid of it. The filter had gaps in it that I could see through and the reducer was so cheaply made I just did not trust it.
My brother-in-law had a Spectre and a metal plate INSIDE the filter that was glued in place let go and got sucked into his turbo doing a lot of damage. Spectre (to their credit) paid him $800 for the turbo. I don't trust cheap crap on my car. I got a cheap LS intake system on my car because I like the build quality of the aluminum piping, nice welds and excellent silicone bend- but I use a high quality Injen filter with it because I didn't like the cheap filter. Spectre isn't crap because they are less expensive. they are crap because they make shoddy equipment. I'm all for saving money and cheap equipment can be just as good as expensive equipment but sometimes cheap shit is just shit that's cheap. |
05-17-2016, 03:56 AM | #13 |
Drives: 2010 V6 | M6 Join Date: Feb 2010
If you don't get enough power or whistles out of your Cold Air Intake then try adding a "scoop". Example: http://www.apex-speed.com/apex-motor...op-051411.html
I went to a body shop and he was able to follow the provided instructions in order to set it up properly for me. I noticed a significant amount of increase in power and the sound of the intake was better with improved air flow. If you rely a lot on your windshield wiper fluid then this mod is not for you. The new fluid reservoir is pretty small but works for me.
BBK 304 LT headers w/ coating | CAI Inc Intake w/ scoop | VMax Ice-olator | MRT v2 | Elite catch can | Trifecta Tune | Eagle halos | 20" Textured Black Forgestar F14s
- They call it the black panther. 2010 Camaro LLT (sold) 2008 Yamaha WR250X 2011 Nissan Armada 4WD Platinum |
05-17-2016, 07:19 AM | #14 | |
It takes 10min to do the install. It is soooooooo easy. |
