05-04-2016, 01:08 AM | #1 |
BUMBL Z
Rate my shopping list
Looking to either lessen or eliminate the rear wheel hop, along with stiffen up my drivetrain with some new mounts. How's my cart looking? Unless I'm missing something, the only thing i'm debating is switching to an adjustable toe rod instead. All rear end parts are BMR and the motor mounts are Prothane
Sold: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower, Custom Camshaft, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, 680rw 93/750rw E85, Tuned by CSP
Sold: 2010 2SS, some bolt ons, 415rwhp/400rwtq |
05-04-2016, 05:45 AM | #2 |
BOHIC
Drives: 2010 Camaro SS "Enola" Join Date: Jun 2014
Shoot an email to T.C. at bmrsales on here. He helped me with my setup below and I haven't heard one complaint (I'm away from the car until June).
Koni yellow shocks/struts and BMR Suspension parts: SP019 Lowering Springs Kit (Set of 4 1 Inch Drop) SB030 Sway Bar Kit F & R BK031 Total Bushing Kit Pro Version SFC015 Subframe Connectors DTB004 Drive Shaft Tunnel Brace TR003 Toe Rods Adj TCA026 Trailing Arm TCA028 Lower Control Arms Non-Adj STB014 Strut Tower Bar ELK005 Front End Link Kit FC002 Camber Bolts
What else can I do to my Camaro?
05-04-2016, 12:03 PM | #3 |
Drives: Race Car Join Date: Sep 2009
Get the BK024 Full Cradle Bushings - Pro Version!
05-06-2016, 03:04 PM | #4 |
BUMBL Z
got it. i'm assuming those would replace the rear cradle bushings I have here?
05-06-2016, 07:02 PM | #5 |
Drives: 2ss/rs Join Date: Apr 2016
NICE LIST... BUT IF YOU ARE LOOKING FOR GET RID OF JUST THE rear wheel hop, that list is over kill.....
05-07-2016, 01:31 AM | #6 |
get full cradle bushings. the Delrin are the best. you can do aluminum too. There will be no noise adding solid cradle bushings. cradle bushing make a big difference.
05-07-2016, 01:42 AM | #7 | |
BUMBL Z
Duly noted, I'll check them out.
05-07-2016, 01:46 AM | #8 |
the motor mounts wont affect wheel hop but you will need all the rest.
05-07-2016, 02:06 AM | #9 |
BUMBL Z
Motor mounts are because mine are shot
05-07-2016, 03:57 PM | #10 |
Drives: 2000 Camaro SS Join Date: Feb 2010
05-07-2016, 07:34 PM | #11 |
BUMBL Z
I notice the bk024 is cheaper than the kit I have in here. Less parts? Not complaining about a smaller bill, just want to make sure I'm not missing out on anything
Sent from my Nexus 6P using Tapatalk
05-09-2016, 11:29 AM | #12 | |
The Cradle Bushings, you can go as hard as you want |
05-10-2016, 06:33 AM | #13 | |
BUMBL Z
