05-02-2016, 02:39 AM | #1 |
Drives: 2015 2SS/RS vert, Spring Green Edtn Join Date: Jun 2014
+1 for the prep towel!
A neighbor of mine pays me to wash and wax her car twice a year. I've never clayed her car because that would take a few hours extra. I recently started using a Speedy Prep Towel on my car, and figured I'd use it hers. It only took about ½ hour. She actually came back over and asked what I'd done differently this time because it "feels smooth as silk." I really think the prep towel gave it that extra "oomph" it needed.
If you use clay, give a prep towel a try - you won't regret it!
2015 2SS/RS vert, Spring Edition Green Flash (2015 - present)
2014 1LT vert, Blue Ray Metallic (2014 - 2015) |
05-02-2016, 11:46 AM | #2 |
Drives: 2011 Camaro LS Join Date: Sep 2008
Was going to buy one but went with the sponge type instead. I've never clayed my car in the 6 years of owning it so we will see what kind of job it does. I've never clayed anything but I liked the idea of being able to wash away dirt or whatever if I dropped it vs having to throw clay away.
05-02-2016, 01:28 PM | #3 |
Drives: 2011 ss rs convertable Join Date: Feb 2015
You can clay a full sized truck or a Tahoe in 20 minuets! Hours???
05-02-2016, 02:01 PM | #4 | |
The SM Arnold Speedy Prep towel has been one of the best purchases I've made for detailing.
Amazon has it for $35.49, which is much less then the detail stores who charge $55 to $60 dollars for it. You can also check paint stores in your area. I picked one up at a PPG store for $33. It's important to get the FINE grade, as the medium is very aggressive and can cause marring. So many advantages, never have to knead, just rinse with warm water, no pressure required, just glide it across surface. If you drop it on the ground, you simply rinse well with warm water and continue. A clay kit will cost you $20 @ wally world or the auto stores, may get 5-6 cars done with it, but you'll have to buy more lube after the first car. This towel and bottle of Ultima Water Wash Plus Concentrate and you can clay 30 cars. The towel lasts up to 100 cars so it's just getting good and broke in after the first 30. From a cost effective standpoint, it's hard to beat. Along with saving lots of time vs. clay, and being easier on your body, makes it a no brainer. EDIT: It's also important to "break it in" on the first use by using it on the glass, it comes with a protective coating on it to ensure no contaminates are stuck to it during packaging, this coating will come off easily when used on glass, it's OK to use light pressure when using it on glass. Fold it in quarters, and use 1 section for front, 1 for each side, and one for rear. You can also put numbers on the back of it so you can flip it when doing paint after a section or 2.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles. Last edited by Joe M 2012 2SS; 05-02-2016 at 02:28 PM. |
05-02-2016, 04:57 PM | #5 |
Joe, of all the advice you've given me, convincing me to get a prep towel was probably the best.
05-02-2016, 05:29 PM | #6 | |
I can't take any credit for it. I learned about it from Matt (CD07).
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles. |
05-02-2016, 05:30 PM | #7 |
Drives: Supercharged 2013 AGM 2SS/RS Join Date: Oct 2013
Have this and am also a big fan. Great product!
2013 AGM 2SS/RS
SLP TVS2300, Edge CAI, 3" Magnaflow catback, BC Racing BR series coilovers, HRE FF15's (20x10 square) with Michelin Pilot Sport 4S's, GM STB, BMR front and rear sway bars and toe links, Prothane subframe bushings and front control arm inserts, JDP rear upper control arm bushings, Elite Engineering catch can. Tuned by Cunningham Motorsports. 1967 Bolero Red 396 SS/RS Convertible |
05-02-2016, 09:28 PM | #8 |
Drives: 2015 Z/28; 1969 Camaro SS Join Date: Nov 2015
05-03-2016, 08:52 AM | #9 |
PREP TOWEL!!!!
It is the best investment I have made -- my two cars are a Camaro and a Yukon - it has cut the time of claying the cars by two hours. Here are the products I use to detail. Once every year or two, I may throw in the IronX too. Of course, when I'm not doing a complete detail, I'll use Adam's Car Shampoo, no DAWN!
2014 2SS/RS VERT L99 SUMMIT WHITE AIRAID CAI BORLA ATAK CAT-BACK EXHAUST ELITE ENGINEERING CATCH-CAN RANGE AFM-DELETE MODULE HUPER OPTIK 40 CHROME PEDALS PREMIUM FLOOR MATS PREMIUM CARGO MAT DEDICATED 32GB iPHONE HD[/I][/B][IMG][/IMG] |
05-03-2016, 12:26 PM | #10 | |
05-03-2016, 01:27 PM | #11 |
between Joe and Matt, we have been well trained.
05-09-2016, 08:04 PM | #12 |
Drives: '13 Triple Black ZL1 M6 Join Date: Aug 2011
Not trying to hi-jack this thread but I just purchased the speedy prep towel thanks to y'all. I have Blackfire SRC Compound and finishing polish but went with Menzerna Powerlock for the sealant. Did I make a mistake? Seems like most use All Finish Paint Protection.
05-09-2016, 08:44 PM | #13 | |
Drives: 18 ZL1 A10 Join Date: Nov 2008
Replying because I tried EVERYTHING on the market, LOL I used the powerlock for 2 yrs now. I now swear by the ALL Finish Paint Protection, I feel it lasts longer than the powerlock and also use complete BF line. Pics or it didn't happen LOL!!
ZL1::J-E-T-S JETS JETS JETS |
05-09-2016, 08:55 PM | #14 | |
Again, BE SURE to break the towel in on the glass to remove the protective factory coating on it! Fold it in quarters like the video shows, 1 side on windshield, 1 side on drivers side, 1 side on passenger, 1 side on back glass. Rinse towel with hose or in a bucket with grit guard, then start on paint. Be sure car has been washed, paint is cool to the touch, and your in the shade. No need to dry car after washing. Use plenty of lube, spray a section around 2'x2' to 3'x3', also spray some lube on the section of the towel your going to use on the paint. Glide it across surface with only enough pressure to keep it on surface, very light. You'll hear and feel the contaminates, as soon as it runs smooth, use a high quality microfiber to remove clay residue, I like RC Everest 1100's, but use what you like, as long as it's a high quality towel. If the car has never been clayed before, flip it after each section to a fresh side. If it only has light contamination, you can use it for 2-3 sections before flipping. Check your section after completion with a sandwich baggie to ensure all contaminates are removed. If you drop the prep towel on the ground, take it to a sink and rinse well with warm water before continuing. Once your done with polising the car, Do a wipe down with a 10% Isopropyl Alcohol/Distilled water mixture, or Carpro Eraser. This will remove any residue you may have missed and ensure the powerlock bonds to the paint. Apply/remove your powerlock. For longest protection with it, apply a second coat 12 hours after first has been removed.
