Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 04-19-2016, 07:33 AM   #1
flipstyledsm22
Let's go fishing!
flipstyledsm22's Avatar
Drives: a car with 8 cylinders
Question Strapping Down The ZL1 On A Trailer
I will be trailering the car this weekend and would like to know what the proper strapping down process is. I would hate to hook on to something I'm not supposed to on these cars.
Please share your experiences and if possible post some pictures of the areas to safely hook on to without damaging the underside of the ZL1.
I will be using a Maxey Drop-N-Load trailer without the E-track (24').
-Ben-
"When choosing between two evils, I always like to try the one I’ve never tried before." Mae West 1892-1980
flipstyledsm22 is offline   Reply With Quote
Old 04-19-2016, 07:52 AM   #2
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
I have trailered my personal street and track cars for 19 years with no issues.
Parking brake on
Car in neutral
Straps through the wheels and crossed in the front (I have protective wheel straps)
Straps through the wheels and crossed in the back
I have one "safety" strap from the tow hook to the floor in the front (may not be applicable)
Straps that are run straight forward/back from wheel to trailer can allow the car to move side to side IF there was an offroad excursion or HUGE bump, curb jump etc. Its all about keeping the car in place in an accident.
Another option is using the holes in the frame used when transporting by rail or car carrier. it is a J or T hook on a chain, but you would need to purchase those.
DO NOT:
Strap to suspension links, trailing arms, swaybars, etc. They are all designed to bent in an accident and can bend in towing. I have seen alignments off as owners didn't even know they bent the trailing arm etc.
Dropspeed is offline   Reply With Quote
Old 04-19-2016, 08:36 AM   #3
Crash76
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500
Let us know if you can get up that trailer with no added Ramps or wood ... Been thinking about getting one
Crash76 is offline   Reply With Quote
Old 04-19-2016, 08:56 AM   #4
flipstyledsm22
Let's go fishing!
Will do.
The new Drop-N-Load trailers have the optional hydraulic jack that you can control the lift or drop with the remote... I believe it can still be added to the trailer, it pretty sick!
Old 04-19-2016, 01:42 PM   #5
Shark72
Shark72's Avatar
Drives: '16 Z06/Z07, '15 Z/28,1972 Stingray
Don't forget the spacer blocks for the front coil springs that came with the original transport delivery of the ZL1.
2015 Z/28 #642 Black Bad Ass
Shark72 is offline   Reply With Quote
Old 04-19-2016, 04:36 PM   #6
THR ZL1 #1
Perma Grinning
Drives: 2012 Tom Henry Racing ZL1
Exclamation
You DO NOT need to put those back in . . . purely needed for added ground clearance for loading and or unloading . .
But to answer the post . . .
I use the body tie down points with "T" towing/recovery hooks
On the belly pan need to route out the holes with a Dremel . . pics below.
Our Garage:
2018 Traverse High Country, 2017 Tom Henry Racing ZL1 Convertible, 2016 Silverado High Country HD, 2014 Camaro SS Convertible, 2012 Tom Henry Racing ZL1, 2002 Berger SS Phase II, 2001 Camaro SS Convertible, 1997 Hendrick Motorsports 30th Anniversary LT4 SS, 1992 Camaro RS Z03 25th . . .
THR ZL1 #1 is offline   Reply With Quote
Old 04-19-2016, 08:42 PM   #7
ZL1Naboz
ZL1Naboz
ZL1Naboz's Avatar
Drives: '13 ZL1, ‘53 Chevy Pickup, ‘22 GMC
What's the enclosed trailer you're running with?
Rotofab CAI, Big Gulp & Washer Bottle Relo, MGW, Kook's w/Hiflo Cats, SCT4, Jannetty, 35% tint, Oracle Side Markers, MTX Sub, Escort 9500ix - Blendmount, 18% Lower, ATI Super Damper, ID850 Injectors, Moroso Catch Can, MSD BAP, AFCO Heat Exchanger
Pre-Pulley Dyno
559.92 RWHP 519 RWTQ
ZL1Naboz is offline   Reply With Quote
Old 04-19-2016, 10:06 PM   #8
Shark72
Shark72's Avatar
No you may need the ground clearance too ...but too answer the post, how far are you are traveling to the track and the roads that you are traveling. The tie down points are just important as the suspension support in the travel to the destination.
Old 04-20-2016, 07:46 AM   #9
flipstyledsm22
Let's go fishing!
I'll be traveling from Houston to San Antonio (Roughly 230 miles, 460 roundtrip).
I bought the ZL1 second hand and there were many missing parts. I don't have the spacer blocks and I also realized the belly pan is missing as well, so I guess I don't have to route those holes until the one I ordered online will come in.
Old 04-20-2016, 08:25 AM   #10
Crash76
Team 913
Do a short video of it going up on the trailer
I want a drop lift bad lol
Old 04-20-2016, 09:24 AM   #11
flipstyledsm22
Let's go fishing!
Will do.
Old 04-20-2016, 11:33 AM   #12
MYLSA
MYLSA's Avatar
Drives: 2014 ZL1 6M
Thinking about getting one of those trailers (see post #4) but what is the minimum size vehicle (towing capacity) to haul that with our ZL1 on it?
2014 ZL1, 6M, Summit White/Black, Carbon Fiber hood insert
2014 2SS/RS LS3 "sold"
ZL1 Exclusive Member
MYLSA is offline   Reply With Quote
Old 04-20-2016, 11:35 AM   #13
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
I use wheel straps like these on all 4 tires, so im not compressing the suspension and or damaging wheels with straps going through them, drove from Wichita KS to lincoln NE with the cruise set at 83 the whole way
http://www.uscargocontrol.com/Towing...FQiQaQod490MJA
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap
ICTsccaCamaro is offline   Reply With Quote
Old 04-20-2016, 02:33 PM   #14
THR ZL1 #1
Perma Grinning
I run a Wells Cargo Autowagon . . extra width and extra height . . I custom built the floor.
Our Garage:
