Old 03-24-2016, 02:31 PM   #1
cwl011
PDR on dash?
In one of the pictures that chevy released the PDR camera looks like it is on the dash or in the mirror. Thoughts? If so this may be easy to install on any camaro.
cwl011 is offline   Reply With Quote
Old 03-24-2016, 02:36 PM   #2
HumanWiki
Drives: Car
It will probably be similar to the C7s and it'll be a front camera in the rear-view, picking up sound from the cabin and tied in to other bits to provide all the vehicle telemetry and overlay.
I don't know offhand how it easy it would be to add after the car is built. You might want to check over on CorvetteForum and see as I believe there's already been discussion on that.
HumanWiki is offline   Reply With Quote
Old 03-24-2016, 02:49 PM   #3
DenverTaco07
DenverTaco07's Avatar
Is there a dashcam mode for the PDR camera? Not sure if it would be needed if you can just activate the PDR and say, drive to work instead of being on a track without it freaking out.
Old 03-24-2016, 02:54 PM   #4
HumanWiki
Drives: Car
It's activated from the Infotainment screen and has a couple different modes
https://my.chevrolet.com/content/dam...te1stPrint.pdf
Starting on Pg 146
Old 03-24-2016, 03:09 PM   #5
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Starting on Pg 146
You can turn it on no matter where you're at. I imagine, together with the Cosworth toolbox, it makes for a wonderful diagnostic tool in some cases.
In order to get lap times, the system sets a Start/Finish line, and uses GPS to track your first lap, essentially "creating" the track each time you use the system. There's a YouTube video out there of a guy driving a Stingray around a bank of parking spaces. The PDR system overlaid an oval-shaped track onto the display after his first "lap".
So I imagine if there's no "lap", it'll just record data for an endless first lap.
Old 03-24-2016, 03:10 PM   #6
DenverTaco07
thx!
Old 03-24-2016, 03:52 PM   #7
tpmotorsports
tpmotorsports's Avatar
Drives: Camaros
Like the Vette and Caddy, only available with NAV and yes its part of the rearview mirror hardware. Not an easy retrofit.
that screen shot is the PDR in Track mode, the green bars are throttle position, red brakes, etc.
'17 ZO6 - Watkins Gray Metallic
'17 911 4GTS - Carmine Red
'17 Bolt - Hyper Blue
'02 SS - 35th Anniversary Ed. - 645 miles
'89 IROC Z - 2500 miles
'73 Z28 - Survivor 36k miles
'69 RS/SS 496 - 631 HP 618 TQ
'67 SS - Alum. 406 under construction
tpmotorsports is offline   Reply With Quote
