03-23-2016, 02:35 PM | #1 |
Drives: 2012 2SS/RS Join Date: Oct 2014
Different Brand Trailing Arm and Toe Rod?
Hey guys I have some BMR trailing arms and I was going to get their adjustable toe rods, but since their about a few weeks out and I have a install next week I went ahead and got the detroit speed adjustable toe rods.
My question is would I be ok running the 2 brands on the car? Thanks. |
03-23-2016, 04:18 PM | #2 |
Drives: Race Car Join Date: Sep 2009
I have ours in Stock in the Black Hammertone color
03-24-2016, 08:03 AM | #3 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
You should be good. I would recommend the upgraded, heavy duty BMR trailing arms and toe rods. I just went to them and wow, those things are big, beefy, solid. I should of installed these to start with based on my HP. I expect these to hold up much better.
03-24-2016, 11:25 AM | #4 |
2010 2SS/RS M6
Drives: 2010 2SS/RS M6 Join Date: Jun 2010
I upgraded my toe rods with ones from a ZL1 and have Spohn trailing arms.
Parts in the rear suspension are mostly just mix & match. Only things to really look into pairing properly would be your dampers & springs. And then making your front and rear sway bars complementary for the rest of the build, but the sways do not have to match brand either (I have Pfadt front and Detroit Speed rears).
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter Bumblebee Racecar Build |
03-24-2016, 01:46 PM | #5 |
Thanks guys. BMR when I called the guy never gave me an option on hammertone.
