Old 03-22-2016, 11:47 PM   #1
ender2664
Drives: 2016 2SS
Custom HUD
Is there a way to customize what shows on the HUD?
ender2664 is offline   Reply With Quote
Old 03-23-2016, 08:57 AM   #2
SSport16
SSport16's Avatar
The only option is to cycle through the info button for the HUD on the left side of the steering wheel and select which screen you want to show.
Old 03-23-2016, 09:04 AM   #3
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
And if you're messing with this in your garage or not moving you won't get the speed limit indicator, you got to be out on a road thats got a posted speed limit sidestreets don't work either
Old 03-23-2016, 10:09 AM   #4
ender2664
Drives: 2016 2SS
Thank you
Old 03-23-2016, 11:41 AM   #5
SSport16
SSport16's Avatar
We still never figured out the whole speed limit display did we? I clearly don't have it, no Nav option in my car.
Old 03-23-2016, 04:07 PM   #6
SuperSound
SuperSound's Avatar
Drives: '17 Camaro 2SS A8
Don't think we did, but all indications are the data is stored in NAV. I think Glen's car is "special" .
Old 03-23-2016, 04:26 PM   #7
SSport16
SSport16's Avatar
Yeah I think that is basically the conclusion.
Old 03-23-2016, 04:32 PM   #8
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Horshit, nothing special about my car....LOL
But someone reported that even cars without nav, have the nav database resident....
I have:
2LT
RS
Lighting and convienence pkg
Onstar working
XM Working
No Nav
But this may be it, as it's only available in certain areas
https://www.siriusxm.com/navtraffic/marketcoverage
Old 03-23-2016, 04:36 PM   #9
Zack46
Zack46's Avatar
Mine works..I get the posted speed limit and of course the speed that I'm doing. Now, it doesn't post the speed limits on every road as Glen indicates above. It must be posted.
Zack46
Production Sequence Number 98
NEOCC Camaro Club Member
Old 03-23-2016, 10:16 PM   #10
asimpleguy
asimpleguy's Avatar
I have:
2LT
RS
Onstar working
XM Working
No Nav
IS IT POSSIBLE THE ONSTAR CONNECTION HAS ANYTHING TO DO WITH IT? ONSTAR HAS THE ABILITY TO DISPLAY DIRECTIONS ON THE SCREEN RIGHT?
asimpleguy is offline   Reply With Quote
Old 03-23-2016, 10:40 PM   #11
SSport16
SSport16's Avatar
I have:
2LT
RS
Onstar working
XM Working
No Nav
My specific city is listed, but I don't have the speed limit option...I know when I had my Traverse LTZ with Nav a few years back, I had the traffic option from XM until the trial ran out,
Old 03-23-2016, 10:41 PM   #12
SSport16
SSport16's Avatar
Yeah but you have Nav option, Glen does not.
Old 03-24-2016, 10:59 AM   #13
SuperSound
SuperSound's Avatar
I have:
2LT
RS
Onstar working
XM Working
No Nav
"The Traffic Speed info is not Speed Limit information, but actual traffic flow(congestion). Here's the info on how they get it from the XM FAQ:
Why is traffic flow information available only on some roads?
Traffic flow information is fed to SiriusXM Traffic by roadway sensors or GPS equipped trucks. The availability of these feeds varies city by city and is limited by road infrastructure and maintenance or the availability of sufficient GPS equipped trucks.
SiriusXM is continuing to incorporate alternative traffic monitoring technologies that will increase availability, speed and flow of roadway data.
Please note, if your onboard map database is outdated, the navigation system may have trouble utilizing all data made available by SiriusXM Traffic broadcasts."
There's no way to send information to XM, you are only receiving signal from the satellite. The only way for the car to display speed limit info is A)the car knows where you are exactly(GPS) B)the car has to have a road database with this info stored for the road you are on(NAV). So XM could have this data stored but it wouldn't know where your car is unless it had access to your car's position via GPS, but that would require your car to send the data to the satellite (which it can't do). Could the data be downloaded to the car and then the onboard GPS and myLink do the work of plotting where you are? Sure, but look at that last note on the XM FAQ.
"Please note, if your onboard map database is outdated, the navigation system may have trouble utilizing all data made available by SiriusXM Traffic broadcasts."
That tells me XM is using onboard map information (NAV) for plotting traffic. So even if XM was the source of Speed Limit info, it would make sense for it to use onboard maps like the Traffic Link does. XM's site also states that their product availability varies by vehicle hardware for the 2016 Camaro.
So again I'm back to pointing out that Glen's (or himself lol) is special. Glen have you had your myLink updated since you first saw the Speed Limit show on yours?
Old 03-24-2016, 11:01 AM   #14
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
No, my car has not seen the dealer since delivery.
