![]() Drives: 2021 Camaro 2LT Join Date: Oct 2013
Factory 2016 Camaro Alignment Specs
got this from my dealer.
2016 Camaro SS(FE3) Alignment Specs, ...............Camber .................Toe Str Front -.75 deg +-.8deg .2deg +- .2 deg ......Rear -.9 deg +-.8deg .2deg +- .2 deg Track Front -1.5 deg +- .15deg .1deg +- .05 deg .........Rear -1.25 deg +- .15deg .1deg +- .05 deg I found it interesting that the factory actually recommended track alignment specs! Last edited by chuckclanton; 03-09-2016 at 02:58 PM. Reason: spacing |
The Dogfather
Drives: #1 off the line for a customer. '16 Join Date: Oct 2015
Amazing find! Thank YOU! Bookmarked it for the future, much appreciated!
Dodges all the cones
Drives: Soon Join Date: Sep 2015
Will be interesting to see how much more camber we can get if the fronts can see -1.5... or.... if we can actually *get* -1.5.
--kC |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
It intrigues me the the stock setting has more negative camber on the rears than the front. It is going to be fun figuring out this car.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. ![]() |
I just got my alignment set up for autocross, I was able to -2.0 out of the fronts._1.6 rear . I have the toe set almost dead even -.01front +.01rear
Drives,
2016 Camaro 2 SS, (OLD CAR)2014 Camaro 1LE, 2SS, NPP Dual Mode Exhaust, K&N Air Filter. E3 Catch Can. z28 Grill, and 1LE Badging Last edited by mcynet; 03-13-2016 at 12:46 PM. |
Here you go! shows RPO restriction, for whom that would apply to.
#7 |
![]() Drives: 2016 V8 Join Date: Jun 2017
#8 |
![]() ![]() Drives: 2016 1SS Join Date: Jan 2016
I was able to get -2.4 in the front with stock SS rims
1SS, Black, Black Wheels, A8, MRC, NPP
