Old 02-24-2016, 06:02 PM   #1
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
Cabin Air Filter replacement
Basically a 3 step process.
Step 1. Open glove box / empty it and unclip the little tension cable
Step 2. Use considerable force to squeeze the box so that the stop pegs clear the dash. Might need some mechanical advantage the first time doing this.
Step 3. Remove filter cover and replace filter.
Reverse process to re-install. Though, I would put the tension cable on before putting the pegs back where they go.
Below are pictures that basically cover that.
Old 02-24-2016, 06:10 PM   #2
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
The Cabin filter is inside the car, this time!?!
YES!
It sounds silly, but I hated replacing it on the 5th gen...made me wince every time I had to peel the cowl piece out of the windshield molding.
Thanks for posting, I hadn't even thought to look into this.
Old 02-25-2016, 04:17 PM   #3
bpang1234
You can only YOLO once.
bpang1234's Avatar
Drives: '16 2SS & '15 Subaru Forester
^^^Yeah it feels a little early for anyone to be replacing it, but at least you got in first!
2016 Camaro 2ss
-Summit White / Ceramic White
-8A, NPP, MRC, Ceramic White package plus knee pads, black bowties.
-1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns.
-1st Car to have the 6LEDesigns Blade Spoiler.
-Borla S-Type w/ custom H-Pipe
-Procharger P-1X Stage 2
bpang1234 is offline   Reply With Quote
Old 06-13-2016, 09:53 AM   #4
efpardo
Deep6
efpardo's Avatar
Drives: 2016 Camaro #182300 | 2SS | HBM
Send a message via Skype™ to efpardo
I was wondering where the filter was. I didn't see it in the manual.
My Journals:
Erick's Mistress - Violet 2016 2SS
#182300 | 2SS | HBM |
Erick’s Mistress - 2010 2LT
#8212 | 2LT | RS | CGM | Litho #165 |
efpardo is offline   Reply With Quote
Old 10-25-2016, 11:10 PM   #5
bodysnatcher
Bodysnatcher
bodysnatcher's Avatar
Drives: 2017 Black RS
how often should it be changed?
bodysnatcher is offline   Reply With Quote
Old 10-25-2016, 11:20 PM   #6
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
It's impossible to say, when you think about it. You may be in some areas where of the car may be susceptible to mildew, or areas that carry smells near industry. I change it annually but also change it whenever I start to smell something it doesn't seem to go away
Old 10-26-2016, 08:03 AM   #7
Mr. Wyndham
The manual says every 22,500 miles...but like Glen said....different regions will require different intervals. This filter had only been in the car for a year and a month or so....absolutely gross.
Old 10-26-2016, 01:52 PM   #8
ny tdi
ny tdi's Avatar
Drives: 2016 1LT V6 6MT Convertible
Ok, dumb question:
How exactly do you "unclip the little tension cable ". I don't see how to do it without fear of braking something...
(Newb moment here)
ny tdi is offline   Reply With Quote
Old 10-26-2016, 02:03 PM   #9
Mr. Wyndham
Originally Posted by ny tdi View Post
Ok, dumb question:
(Newb moment here)
It fits into a slot....slide forward.
Old 10-26-2016, 11:07 PM   #10
ny tdi
ny tdi's Avatar
Got it, thanks!
Old 11-22-2016, 02:43 PM   #11
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Finished! Found the door, I wasn't looking high enough. Another tip is to lightly spray the filter with a scent, I use a leather scent, the car smells fantastic -caution -don't use too much!
Old 11-22-2016, 02:56 PM   #12
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
I'm 2000 away from 22,000 miles, i will post a pic of how mine looks when I change it in a month or so.
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 11-22-2016, 10:11 PM   #13
SSport16
SSport16's Avatar
Anyone try those Fram fresh cabin filters, think they have Arm & Hammer scent, they are quite pricey, not sure if they are worth it.
Old 01-02-2017, 05:48 PM   #14
Ruebernard
Ruebernard's Avatar
Drives: 2023 Radiant Red Tintcoat 2SS
Okay this was a bust....unclipped the tension cable but can't get the glove box pegs free what sort of mechanical "advantage did you use??? At this point I cannot reach the tensioner to put it back in place and cannot shut the glove box.
If it were more fun, it would be illegal!
Ruebernard is offline   Reply With Quote
