dave@hennessey
Old 02-24-2016, 09:01 AM   #1
Gi0vanni2ss
Drives: 2010 2ss Camaro
LS3 tune up
Hey Guys!
A while a go I posted about finding out what type of maintenance to do at 55k and what to look out for, someone recommended I hit the throttle body was some Carburetor cleaner. Any other tips on fuel maintenance, Will any carburetor cleaner work or is there a special bottle out there I should know about. what about additive or any injector treatment? again its only 55K on my 2010 2ss LS3.
Thanks!
Gi0vanni2ss is offline   Reply With Quote
Old 02-24-2016, 09:06 AM   #2
Gregss1le
Asskicker
Drives: '15 Camaro Blue Velvet Metallic 1le
Manual or auto car ?
2015 Camaro 1ss 1le
1991 Camaro LsX-not stock
Gregss1le is offline   Reply With Quote
Old 02-24-2016, 09:17 AM   #3
NC_SS
NC_SS's Avatar
Drives: 2012 M6 Camaro SS (RIP)
Uh why would you use carb cleaner on a fuel injected engine, even if it is just the TB?
Fuel treatments are snake oil IMO, but some top tier Shell treated 93 would probably be good to run every now and again.
NC_SS is offline   Reply With Quote
Old 02-24-2016, 09:18 AM   #4
JLSuperfly
JLSuperfly's Avatar
Drives: 2014 Red Hot LS3
LS3, manual.
JLSuperfly is offline   Reply With Quote
Old 02-24-2016, 09:53 AM   #5
EFI
EFI's Avatar
Drives: something faster than you
Carb cleaner does not work solely on carburators. It's simply a cleaning agent for fuel and oil related deposits. AFAIK, fuel and oil are still used even in today's fuel injected enigne...thus the same carb cleaner works in cleaning today's components. Now whether or not this will fix the OP's issues that's another story.
EFI is offline   Reply With Quote
Old 02-24-2016, 10:02 AM   #6
AppleBomb
AppleBomb's Avatar
Drives: 2013 2LT/RS, 2013 Mustang GT/CS
+1
AppleBomb is offline   Reply With Quote
Old 02-24-2016, 10:02 AM   #7
Gi0vanni2ss
thumbs up!
Old 02-24-2016, 10:16 AM   #8
Skillet
Drives: car
Bingo!
Can I use dish soap to wash my hands or do I need to use hand soap?
Skillet is offline   Reply With Quote
Old 02-24-2016, 10:30 AM   #9
OrangeVert
"Catharine"
OrangeVert's Avatar
Drives: '11 2SS/RS LS-3 IOM/IO vert
I'd be careful not to spray carb cleaner in a running engine - heard that could possibly harm O2 sensors. Don't know that for a fact, but would rather err on the side of caution.
OrangeVert is offline   Reply With Quote
Old 02-24-2016, 12:59 PM   #10
NC_SS
NC_SS's Avatar
Fair enough, my stock TB looked pretty good at roughly 48,000 miles
Old 02-24-2016, 01:17 PM   #11
Dmpsix
Dmpsix's Avatar
Drives: Black L99 2SS/RS
Originally Posted by Gi0vanni2ss View Post
Hey Guys!
Thanks!
Hmm... using some lubricant for weatherstripping and all the rubbers isn't a bad idea either
http://www.ebay.com/itm/like/1418710...chn=ps&lpid=82
Dmpsix is offline   Reply With Quote
Old 02-24-2016, 01:18 PM   #12
Gregss1le
Asskicker
I would pull the TB, give it a good clean over with whatever anyone uses. I use Brake Kleen a couple bucks a can, I also use simple green, cause its safe on aluminum, yet cleans anything. I wouldn't change the plugs unless there is an issues with them. Todays plugs can go 100k without any major problems.
I would also change rear diff fluid, inspect brake/clutch fluid, if its dark and dirty, flush it out. Cabin filter, if equipped, inspect change if needed.
Personally I run a bottle of Marvel's Mystery Oil in all 4 of my vehicles, my boat and my yard tractor. 1-16 bottle to a full tank of gas, (depending of tank size of course) it cleans and lubes injectors, fuel pump and doesnt hurt anything. My 2004 Envoy has over 260k on it and I have used Marvels Oil since after the first summer (original owner)
2015 Camaro 1ss 1le
Old 02-24-2016, 01:22 PM   #13
Gregss1le
Asskicker
its the back side that is probably filthy, remove it and clean thoroughly and discount the battery for a little more 20 mins. The throttle will be more responsive and idle a hella lot better. I can tell when my TB on the Envoy is in need of a bath, just by the way it idles. (rough/throttle is sluggish)
2015 Camaro 1ss 1le
Old 02-26-2016, 12:42 AM   #14
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
remove the tb to clean it. the o ring is reusable. Dont know if brake clean will harm the tb sensor. I just use TB cleaner. you can clean the MAF too. You need MAF cleaner to do that. rear diff fluid
