Old 01-22-2016, 01:07 PM   #1
jimmypop13
Drives: 2016 camaro ss
Full wireless control of NPP valves.
I never liked the fact that the NPP valves still close in sport and track mode at low rpms or while cruising so this was an easy way around it. I found it on the corvette forums and it was just as easy to do on our car, only you use fuse 51 on ours.
You can either control the valves like I do in the video with the included transmitters or program the homelink buttons in the car if you don't want to keep a transmitter lying around in the center console. I used the big ground point right outside the fuse box and put a quick disconnect on it so the whole thing can be removed and returned to stock in about 30 seconds. The fuse box lid snaps on the right side but not on the left due to the two ground wires running out. I did notch the corner of the box there but it looks like the lid will need a little notch as well if I want it to snap down.
I set the car exhaust mode on the touchscreen to stealth and I'll just use this to control whether the valves are opened or closed. When you start the car it does default to open but if you just hold close button down while starting, it immedately closes upon firing and will be quiet.
It cost me about $30 for everything and I think it was well worth it! Here is the how-to guide, a video, and a pic of how I did it:
http://www.corvetteforum.com/forums/...ob-how-to.html
EDIT: I have since modified mine to be the same as in post #16. Having the ground in the fuse box makes everything so much easier
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS
RIP : 2002 WS6 Black, A4, 355rwhp
jimmypop13 is offline   Reply With Quote
Old 01-22-2016, 03:01 PM   #2
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
looks like a legit mod.
Sledgehammer70 is offline   Reply With Quote
Old 01-22-2016, 03:08 PM   #3
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
That's pretty trick! You should post this in the DYI section as well.
Eric SS is offline   Reply With Quote
Old 01-22-2016, 03:14 PM   #4
Tr6
The Dogfather
Drives: #1 off the line for a customer. '16
Great find! Post this on the how to / diy section too!
2SS, Garnet Red with Adrenalin red, NPP, MRC M6 coupe
#33 off the line #1 order for Customer.
Build thread HERE!
Story of my delivery HERE!
Tr6 is offline   Reply With Quote
Old 01-22-2016, 03:16 PM   #5
Sledgehammer70
Lethal Camaro
Will this update keep the valves open all the time? I mean both sets?
Old 01-22-2016, 03:18 PM   #6
Eric SS
#becauseracecar
Eric SS's Avatar
I could be wrong but I believe there's only 1 set of NPP valves and they're on the outboard tips. And this mod allows you to chose between slealth and open wirelessly.
Old 01-22-2016, 03:19 PM   #7
Kracka
Drives: 2021 Corvette Z51
If you have the A8 transmission, you will have to keep your car running in 8-cylinder mode. If you have the M6, the AFM valves are no concern for you.
Kracka is offline   Reply With Quote
Old 01-22-2016, 03:31 PM   #8
leadfoot93
Camaro Fan
leadfoot93's Avatar
Drives: 2016 Camaro 1SS Garnet Red
Very cool!
Ordered: Garnet Red Tint coat 2016 Chevrolet Camaro 1SS, Auto, NPP
1100 Status: 8/6/15
3800 Status: 10/13/15 VIN #116519
4200 Status: 12/19/15
Delivered : 12/28/15
leadfoot93 is offline   Reply With Quote
Old 01-22-2016, 04:21 PM   #9
jimmypop13
No this will only keep the rear valves open at all times as it controls whether fuse 51 is in or not. There is another fuse for the afm valves but it will throw a code if pulled. You would need to buy the Range device to keep afm off or tune it out
Old 01-22-2016, 04:26 PM   #10
The1DoubleN
Drives: Blown up '16 SS
Awesome job. So if I wanted to achieve the same result the lazy way, I just pull fuse 51 and my valves are always open?
The1DoubleN is offline   Reply With Quote
Old 01-22-2016, 04:30 PM   #11
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
http://www.camaro6.com/forums/showpo...76&postcount=7
Old 01-22-2016, 05:00 PM   #12
jimmypop13
Yup!
Old 01-23-2016, 02:09 PM   #13
SPCBA
Drives: pleather and Chiclets
Cool writeup man. Does it control it enough to keep closed on startup?
SPCBA is offline   Reply With Quote
Old 01-23-2016, 02:13 PM   #14
jimmypop13
You do have to hold down the button on start up bc it gets reset while cranking. A minor annoyance
