Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - California
Old 01-21-2016, 12:31 AM   #1
HAMBO
HAMBO's Avatar
Drives: Supercharged 2013 AGM 2SS/RS
List of CARB Approved Camaro Mods
I’ve noticed a few people asking for “is there a CARB-legal version of mod X?” or "is replacing part Y CARB-legal?". I’ve asked those questions a few times myself. Since CARB doesn’t let you search their aftermarket parts database by car model, it’s hard to figure out what’s been approved in California for the 5th gen Camaro specifically. Clearly there are plenty of mods to do out there that aren't CARB compliant (many of which you probably wouldn’t get busted for, or that are legal for “off-road use only”), and plenty of threads about how to make mods hard to detect or how to swap back to stock before smog check, but for anyone interested in finding stuff that is truly CARB legal, I thought it might be helpful to prepare a thread of CA-legal mods. I had already researched a bunch of these over the past while, so figured I would share them in case they are helpful to anyone.
After doing some digging, here are the things I’ve found that are certified legal in CA. Please note some of these are tied to specific model years. Not really sure what that implies for later model years (since nothing much has changed from what I understand).
Cold Air Intakes
Volant - for V6 only: http://arb.ca.gov/msprog/aftermkt/de...eo/D-526-7.pdf
AEM Inductions & AirAid – True CAI for V6 only, with some strange ‘air filter and tube’ combo for the SS http://arb.ca.gov/msprog/aftermkt/de...o/D-670-20.pdf http://arb.ca.gov/msprog/aftermkt/de...o/D-609-11.pdf
K&N – True CAIs for the V6 and ZL1 only, same type of filter and tube thing for the SS: http://arb.ca.gov/msprog/aftermkt/de...o/D-269-49.pdf
Powerteq - Jammer CAI for 6.2L: https://arb.ca.gov/msprog/aftermkt/devices/eo/D-802.pdf
Throttle Body
JET performance: http://arb.ca.gov/msprog/aftermkt/de...o/D-234-10.pdf
BBK 95mm and 102mm: https://arb.ca.gov/msprog/aftermkt/d...o/D-245-17.pdf
There are a bunch of throttle body boosters / spacers that are CARB approved, but from I understand those don’t really add any power so I’ve not bothered to list them.
Intake Manifold
LSXR:http://arb.ca.gov/msprog/aftermkt/de...eo/D-279-9.pdf
MSD Atomic Airforce (for Z28/LS7 only): https://arb.ca.gov/msprog/aftermkt/d...eo/D-722-1.pdf
Superchargers
Magnuson: http://arb.ca.gov/msprog/aftermkt/de...o/D-488-17.pdf and http://arb.ca.gov/msprog/aftermkt/de...o/D-488-21.pdf
SLP: http://arb.ca.gov/msprog/aftermkt/de...o/D-187-21.pdf
Whipple: http://arb.ca.gov/msprog/aftermkt/de...o/D-231-32.pdf
E-Force: http://arb.ca.gov/msprog/aftermkt/de...o/D-215-73.pdf
Kenne Bell: http://arb.ca.gov/msprog/aftermkt/de...o/D-271-27.pdf
Turbochargers
Turbonetics stage 1: http://arb.ca.gov/msprog/aftermkt/devices/eo/D-99-7.pdf and http://arb.ca.gov/msprog/aftermkt/devices/eo/D-99-8.pdf
Heads
TrickFlow: http://arb.ca.gov/msprog/aftermkt/devices/eo/D-747.pdf
Edelbrock: https://arb.ca.gov/msprog/aftermkt/d...o/D-215-98.pdf
Air Flow Research: https://arb.ca.gov/msprog/aftermkt/d...eo/D-250-5.pdf
Cams
GM LS3 Heads and Cam Upgrade: https://arb.ca.gov/msprog/aftermkt/d...o/D-126-45.pdf
Comp Cams Stage 1 Cam for 6.2L: https://arb.ca.gov/msprog/aftermkt/d...o/D-279-11.pdf
Comp Cams Stages 1-3 for 6.2L: https://ww3.arb.ca.gov/msprog/afterm...o/d-279-12.pdf
Rocker Arms
SLP: http://arb.ca.gov/msprog/aftermkt/de...o/D-187-20.pdf
Exhaust Headers
ARH shorties: http://arb.ca.gov/msprog/aftermkt/devices/eo/D-693.pdf
JBA shorties: http://arb.ca.gov/msprog/aftermkt/de...eo/D-57-25.pdf
Flowmaster shorties: http://arb.ca.gov/msprog/aftermkt/devices/eo/D-698.pdf
Gibson Performance shorties: http://arb.ca.gov/msprog/aftermkt/de...o/D-411-11.pdf
Pacesetter Shorties: https://arb.ca.gov/msprog/aftermkt/d...eo/D-439-9.pdf
Gears
SO, I don’t really understand how swapping gears impacts emissions (if someone does, please explain). There could be an argument that they don’t, and hence don’t need approval (since CARB is meant to control products that are ‘before the catalytic converter and affect emissions’). That said, the GM 3.91 gears are CARB certified. I’m not sure why GM would have gone to the trouble and cost of certifying them if they didn’t have to, but who knows.
GMPP: http://arb.ca.gov/msprog/aftermkt/de...o/D-126-35.pdf
Tuning / Other
Range AFM Plus: http://arb.ca.gov/msprog/aftermkt/devices/eo/D-751.pdf
Hypertech tuning devices: http://arb.ca.gov/msprog/aftermkt/de...o/D-260-15.pdf and https://arb.ca.gov/msprog/aftermkt/d...o/D-260-22.pdf
Superchips Flashpaq: http://arb.ca.gov/msprog/aftermkt/de...o/D-330-15.pdf
Z Industries: https://ww3.arb.ca.gov/msprog/afterm...eo/d-264-2.pdf
From what I understand, things like suspension changes, wheels, tires, anything related to exhaust but behind the converter (and theoretically anything that can’t impact emissions) doesn’t require CARB certification. Neither does wear and tear stuff like replacement air filters, spark plugs or wires.
Please add to the list if you know of more things!
2013 AGM 2SS/RS
SLP TVS2300, Edge CAI, 3" Magnaflow catback, BC Racing BR series coilovers, HRE FF15's (20x10 square) with Michelin Pilot Sport 4S's, GM STB, BMR front and rear sway bars and toe links, Prothane subframe bushings and front control arm inserts, JDP rear upper control arm bushings, Elite Engineering catch can. Tuned by Cunningham Motorsports.
1967 Bolero Red 396 SS/RS Convertible
HAMBO is offline   Reply With Quote
Old 01-21-2016, 09:38 AM   #2
kmarshall2121
kmarshall2121's Avatar
Drives: 2012 45th Anniversary Edition
nice list - I use Volant in all my vehicles for just that reason. Comes with a CARB compliant sticker you can affix close to the CAI...
kmarshall2121 is offline   Reply With Quote
Old 01-21-2016, 11:05 AM   #3
kmarshall2121
Originally Posted by CreativeDawn View Post
I have Doug Thorley Shorty Headers on my Camaro. This sucks, I don't want to remove them just to pass the Smog Test. I hope a Star Center doesn't make a big deal about them since ARH is legal and they have the same principle.
I'm going to order an aftermarket CARB legal Intake so I can pass that part. I currently have a long-tube INJEN which I like and I don't like anyways since it goes to close to the ground near tire-well.
I sure hope Doug Thorley can push to get theirs CARB LEGAL before I need to smog in May.
all the smog places do is 'plug and play' - and visual inspection. as long as you don't throw any codes, I'm pretty sure you'll be fine.
Old 01-21-2016, 02:22 PM   #4
macwest
Drives: 10 Camaro 2SS/RS, 70 Cuda, 71 Cuda
Just point to doug headers number. I would bet using the number from doug headers most shops would not know any difference between doug thorley or doug headers and there would be no issues.
"Z28 = first time I bought a new car just to strip parts for my current ride. GM needs to re-think restricted parts. "
macwest is offline   Reply With Quote
Old 01-24-2016, 12:56 AM   #5
Dlsbobby
Dlsbobby's Avatar
Drives: 2010 Camaro ss M6
Hambo,
Hats off to you for doing the leg work. You just helped a lot of people.
I think Kenne Bell has a Carb approved supercharger for Camaro also;
http://arb.ca.gov/msprog/aftermkt/de...o/D-271-23.pdf
Dlsbobby is offline   Reply With Quote
Old 01-26-2016, 03:47 PM   #6
HAMBO
HAMBO's Avatar
Originally Posted by Dlsbobby View Post
Hambo,
Thanks!
Great, thanks for the link. I'll add to the original post.
2013 AGM 2SS/RS
Old 01-26-2016, 08:17 PM   #7
Jackass
Doing what I like to do
Jackass's Avatar
Drives: 1963 Landrover
Hambo , good thing they don't worry about the gears regarding the CARB thing
Because if they ever come up with that , ( like they do in Europe ) the days with cars that get bigger wheels , wider wheels and or tires will be a thing off the past , for the very same reason as switching the gears , different thing , same result
Jackass is offline   Reply With Quote
Old 01-27-2016, 09:25 AM   #8
kmarshall2121
CARB stands for California Air Restrictions Board - only monitors emissions controls and issues. Gears would have nothing to do with air.
Old 01-31-2016, 10:11 PM   #9
HAMBO
HAMBO's Avatar
Updated to include Flowmaster shorty headers.
2013 AGM 2SS/RS
Old 02-11-2016, 11:30 AM   #10
2Intense
Drives: 2015 Camaro RS
I just installed this CARB compliant K&N Air Intake system: http://www.knfilters.com/search/prod...x?prod=57-3074
Can anyone recommend the best CARB compliant headers?
What are the expected/reported performance gains from the headers?
2Intense is offline   Reply With Quote
Old 02-11-2016, 11:38 AM   #11
clarkkent
Drives: 2013 2SS (sold)
Regarding the gears, theoretically, if you are crusing down the freeway at 70 in 6th gear with 3.43's you're pulling 1700 rpm's or something. You switch to 3.91's and you're pulling 2100 rpm's at the same speed. You are producing more emissions since you are at a higher rpm, so gears do in fact effect emissions. It's one reason why cars these days have such tall overdrives/double overdrives, not for "driver comfort". [those numbers are off the top of my head, but you get the idea]
That being said, not sure if CARB cares about that or not. But just wanted to point out that gears can effect emissions. Do they effect them that much? No, but still I could see the EPA caring about that to some degree
clarkkent is offline   Reply With Quote
Old 02-11-2016, 12:07 PM   #12
HAMBO
HAMBO's Avatar
Interesting. I am also guessing, and this is just a guess, that part of the issue may be that new gears require a new tune (if only for the speedometer). I think any part that requires a new tune may need a CARB E.O.
2013 AGM 2SS/RS
Old 02-11-2016, 12:10 PM   #13
HAMBO
HAMBO's Avatar
Cool. How do you like the tube/filter combo? Did you notice any difference?
For headers, only the shorties above are CARB compliant, and from what I've heard shorties in general don't offer any meaningful gains vs stock for an SS. For what it's worth I've heard ARH products are very high quality, and that their shorties are better quality than others.
2013 AGM 2SS/RS
Old 02-11-2016, 12:42 PM   #14
2Intense
To be frank, not a damn bit of difference...
