Retired from Car mfrs....
1st oil change v-6 install w/ stahlbus valve
So here's the jist of the first oil change on the V-6. First the ramps. I own these ramps:
http://www.amazon.com/gp/product/B00...rch_detailpage simply center them and drive on. Since the drain bolt is at the back, no need to level the car when draining. if you're a big guy I suggest a ramp a few inches taller, but this works fine for me. ![]() ![]() The drain bolt is 19 mm and also has a torx center. V8 and v6 use same bolt. The oil drain was straightforward, pull the bolt, drain and screw in new valve. ![]() Now before I get the usual posts about it sticking down , IT DOES NOT. The Fumoto 107s valve would, but this is still 1/4" higher than your cladding and cross strut brace. You will destroy the lower end before the valve scrapes. I am in Florida where the roads are smooth so no worries. For the oil filter I use a little trick I learned on my 300 Mercury Verado's we've used in the past couple years - get a big trash bag and loosen filter, snake the open end of the bag over the oil filter, keep unscrewing and all the messy oil and filter drop into the bag. So now I'm set to do oil changes at my condo which would cost me a penalty if I spilled anything. Enjoy, more info and videos on the stahlbus site here, from Germany, it’s got that precision feel to it. Not cheap @$55. http://www.stahlbus.com/products/en/oil-drain-valve/ the size to use is M12 x 1.75 this should be the same for v6 and v8.- see Fred at reverse logic : http://www.reverselogic.us/stahlbus.html one other note, no matter how easy oil changes are, wear Nitrile gloves..oil can be cancerous...100 pr off amazon for 10 bucks. I wear them for most mods/work. Edd China of wheeler dealers, , IMO the greatest tech on TV, taught me that....
![]() Drives: '95 Corvette, '06 Mustang, 2LT RS Join Date: Dec 2015
Excellent. Thanks!
I just got my TPW so I feel like it's real enough to start ordering parts and such. Edit: Can we make stuff like this sticky? |
![]() ![]() ![]() ![]() Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ! Join Date: Sep 2015
Great write up! Does the v6 camaro not have the black plastic pieces on the bottom of the bumper or did you remove yours? Maybe I just do not see them at this angle? Mean make it a pain on ramps.
#4 | |
If they were on, they would slightly drag across the ramp, but no damage done. If you want to get super Duper ramps that would have absolutely no problem, see Fred's site for his ramps, Longer ....
![]() ![]() ![]() ![]() ![]() Drives: Gen 6 Camaro RS Join Date: Dec 2015
Lots and lots of good info. Now i am considering doing the oil change instead of going to the dealer. thanks
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
Pretty cool! Might have to start changing my own oil again!
#7 |
What filter did you use, AC Delco? If so what PF #?
#8 |
Exactly what is in manual- yes, ac delco pf63e off amazon + Mobil 1 Extended Perf 5w-30
Took 5 qts even with pretreated filter to mid stick.
#9 |
10 quarts for the SS!
#10 | |
Camaro Fan
what is Fred's site? also I am going to give you a call over the weekend about the knee pads.
Ordered: Garnet Red Tint coat 2016 Chevrolet Camaro 1SS, Auto, NPP
1100 Status: 8/6/15 3800 Status: 10/13/15 VIN #116519 4200 Status: 12/19/15 Delivered : 12/28/15 |
#11 |
![]() ![]() ![]() Drives: 2016 camaro ss Join Date: Oct 2010
I like this. Ordering now!
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS RIP : 2002 WS6 Black, A4, 355rwhp |
#12 |
read my post again, it's there...I'm keeping pads...
#13 |
![]() Drives: 2x 94:Z28s - 2x95:Z28s - 1x16:1LT Join Date: Nov 2015
I see rust and dirt...bad-gu-gu
![]() Nice write up! ill have the dealer change my oil until its no longer free. Thanks again! |
#14 | |
![]() ![]() ![]() Drives: 2016 V6 RS Camaro 6MT Join Date: Aug 2015
But, now you have me thinking about removing them as well. They don't look good. Can anyone advise what function these serve? Any function that would impact the car for daily driving? Glen I'm just following your lead and copying everything you do lol . You've even got me considering changing my own oil again. Haven't done it for years. But, $40 an oil change vs $80 is sounding pretty good.
Summit White 2LT RS V6 ZN2 NPP m6 khalihari interior. Order placed 9/26/15 - Picked up 12/17/15!
