12-16-2015, 12:51 PM | #1 |
Drives: 2013 Camaro 2lt RS Join Date: Apr 2015
Tire sizes
Does anyone know if these tires sizes would look on a 2013 camaro RS? The car on my signature plus im going to lower it 1.2 all the way around with BMR springs.
Thanks 275 40 20 front 305 35- 20 back
12-16-2015, 01:58 PM | #2 |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
Not on those rims ... they are too small
12-16-2015, 02:34 PM | #3 |
Drives: A real beast Join Date: Dec 2014
Rims are too small I'm afraid
12-16-2015, 03:24 PM | #4 |
Drives: 2013 Camaro 2LS Join Date: Oct 2015
i took this screenshot a while ago from another thread on tires for future references, but i don't have the link to it
2013 2LS - K&N CAI, Overkill Ported 80mm Throttle Body, Overkill E85 Kit and Overkill Tune, Jacfab Ported Intake Manifold and Spacer, Stealth 3.0 TC, ARH Catted Downpipes, Magnaflow Resonated X-Pipe, Resonator Delete, Jones Full Boar Racing Mufflers, BMR 1.2" Lowering Springs, Elite Engineering Catch Can and Clean Side Seperator
12-16-2015, 05:09 PM | #5 |
GRIM
Drives: 2015 Camaro Z/28 Join Date: May 2010
I have stock rims on my 2010 Camaro SS. I am running 305 35 30 MT on the rear. I had no fitting issues.
12-16-2015, 06:28 PM | #6 |
So they will fit on my car then?
12-16-2015, 06:30 PM | #7 | |
Thanks
12-16-2015, 06:33 PM | #8 |
having FUN now 13.66@101
Yes, the tires will fit. Will someone mount them for you. Maybe not. The minimum wheel size is not met, and can be dangerous during certain handling conditions. With the proper wheel size and offset the tires will fit with NP using the 1.2 drip. Many have done this already.
12-16-2015, 09:18 PM | #9 |
i'm pretty happy with them. the car feels a little more planted and it looks way better. the ride quality is slightly more harsh, but barely noticeable, and you get used to it in a week. there's maybe 2.5" of gap left now and i'm running 20's. it's low enough that it will hit parking curbs and if you're going fast the bottom will hit speed bumps. i also think that 1.2" is as low as you can go on the v6 without having to do anything crazy to the suspension, so for $210 they're well worth it.
12-16-2015, 09:41 PM | #10 | |
12-17-2015, 10:09 PM | #11 |
GRIM
The MT 305 35 20's will fit. I'm also running 1.25 apex lowering springs. Absolutely a difference in handling. Monroe Muffler shop took care of me w/ install of tires. If you are on or near s military base, normally all bases have a auto craft shop... They also normally have the ability to install & balance. The tires went on fairly easy.
I hope this helps. |
12-18-2015, 04:50 AM | #12 |
Thread moved to the tire section where there's a Sticky Thread of proper sizes.
