11-20-2015, 10:58 AM | #1 |
Performance-Dyno.com
Drives: 2013 Camaro ZL1 Join Date: Mar 2010
10% Pulley Results
Hi All, in mid October I installed the IW 8.6" overdrive lower pulley. I made dyno pulls before and after the installation... verified coolant, intake temp, and intake temp 2 were all at the same level for the pulls. It certainly made good gains. The air-fuel starts to pull lean at the top-end because the injectors can't keep up.
p.s. Don't mind the 13psi boost number, there is a small spike when I tapped the rev limiter.
2013 Camaro ZL1 - 10% pulley, roto-fab, tune
575 rwhp street temps, 604rwhp glory pull tuned by me at Performance-Dyno.com Last edited by jlpearl; 11-27-2015 at 05:24 PM. Reason: NOTE: This is an 8.6" pulley which is ~10% not 5%!! |
11-22-2015, 07:51 PM | #2 |
Drives: 2013 crystal red tintcoat zl1 Join Date: Nov 2015
Did you have to get it tuned and where did you get your 5% pulley from? I would like to do the same upgrade.
11-22-2015, 10:24 PM | #3 |
Sarcasm loading --------
how are you getting 12 lbs from a 5% pulley?
Do you have an upper pulley on it?
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
11-23-2015, 05:42 AM | #4 |
Drives: 2014 Subaru Forester Turbo Join Date: Aug 2013
Something not right here lol
11-25-2015, 09:53 PM | #5 |
Great catch guys. I just checked the invoice and it is a 8.6" pulley. I was originally planning for an 8.1" which is 5%, but ended up with this one and never cleared it up in my brain. I adjusted the content of the above post accordingly. Sorry for the confusion!!
Regarding the tune, this is something I do myself with HP Tuners at our dyno shop in NH.
575 rwhp street temps, 604rwhp glory pull tuned by me at Performance-Dyno.com |
11-27-2015, 12:38 AM | #6 |
You should change the title to 10%.
11-27-2015, 02:09 AM | #7 |
Drives: 2014 Camaro ZL1 Join Date: Dec 2014
8.66 is 10% not 5%
Lingenfelter 630Hp Package , Afco Heatexchanger , Moroso Catchcan , D3 Tank , Siemens 63Pds/hr Injectors , Custom tune.
11-27-2015, 07:11 PM | #8 |
Drives: 2015 ZL1 Join Date: May 2015
A6 or M6?
ERL 434 LSA super block with 6 bolt 1/2" studs
Ported stock blower 2.55/9.55 and NW 102 tb 5" JLT CAI, custom radiator Mamofied TFS heads with 1.8 Y/T rockers and Johnson lifters FI interchiller E85 flex fuel Circle D 3200 Tuned by Speed inc. 755/730 on 93 and 850/822 on corn |
11-28-2015, 07:08 AM | #9 |
This is an M6
12-10-2015, 02:58 PM | #10 |
Drives: Camaros, BMWs, Cummins, Ninja Join Date: May 2012
what else do you have for mods? or is it just this pulley and tune?
12-10-2015, 06:31 PM | #11 |
I have a Roto-Fab intake too, which was already installed for the baseline
