11-14-2015, 09:44 AM | #1 |
Drives: '17 1SS 1LE & '15 Corvette Z06 Join Date: May 2009
New 20" MRR Z28 Style Rims for 1LE Showed up 2day!
Picked up some 20" Z28 MRR rims for all season tires. Very nice.
Bob's House of Wheels, with black lug nuts, GM rubber stem TPMS and GM Z28 OEM center caps for $1,299 delivered. Stock sizes (10's front, 11's rear). Mount and balance 4 - BF Goodrich A/S 285 35 R20's from Tire Rack on Monday at KC Trends here in KC. Last edited by bub; 11-14-2015 at 10:14 AM. |
11-14-2015, 10:02 AM | #2 |
2013 Camaro SS1LECTSVZ28
Drives: 2013 AGM 1SS/1LE Join Date: Nov 2012
You are putting these on a 1LE? I am not a fan of the MMR wheels, which are cast and made in China,replacing the stock forged wheels. Driven on the street there "should" be no issues. If you plan to track the car I would highly recommend the stock wheels.
Matt
11-14-2015, 10:04 AM | #3 |
Winter season street-only for the MRR's with all-season (<40 deg F) BFG's.
Keeping the forged stock rims with GY's in storage over winter. 2 complete sets of wheels and tires to swap seasonally. |
11-14-2015, 10:59 AM | #4 |
Drives: 2014 2SS/RS/1LE Join Date: Mar 2015
Very nice and great price too. I plan on getting some of those eventually. Obviously not for track purposes, they just look badass.
11-18-2015, 08:37 PM | #5 |
OK...got these all mounted and balanced up and installed them on the car tonight. Son and I started out for a test drive and we hear this clicking sound...click, click...pause...click, click...pause....
Hmmm...turns out the rubber valve stem TPMS was clipping the caliper balance counter weight thingys on the front calipers both sides by a fraction of an inch. For now, we took some super sticky gorilla tape about 6" long and stuck the flexible rubber valve stem down towards the rim, essentially bending it away from the interference. Clears by like 3/16" now. Not sure this is my best long term fix, but gets us back on the road. I know OEM TPMS is metal stem, so that may be lower profile than the rubber stem that came with my wheel set. Tried taking off the valve stem caps to buy some added clearance just to see if bare stem would clear, but even the bare stem still clips the weights. Crummy design placement of the stems back into the barrel of the rim if you ask me on these MRR's. Was a bit concerned about this when I bought them but figured surely they checked for caliper interferences Anyone else run into this issue and how did you resolve it? Is there a low profile TPMS that clears the front calipers better? Pics coming soon. of rims and temp solution with the gorilla tape to better illustrate the issue. Last edited by bub; 11-20-2015 at 05:26 PM. |
11-18-2015, 08:46 PM | #6 |
HTCC Membership Director
Drives: 2013 RS Camaro Join Date: Jan 2014
You could Change your brake pads to eliminate the skates
Sent from my iPhone using Tapatalk |
11-18-2015, 08:49 PM | #7 |
11-18-2015, 10:16 PM | #8 |
Chiquita
Drives: 2013 1LE/1SS YELLO1LE 1 of Only 28 Join Date: Nov 2011
Strange I ran my MRR's even with Caliper covers no PROB? But now my Cars a 2013 There might be the difference.
11-19-2015, 06:14 AM | #9 |
You can do one of 3 thing to prevent the contact.
1. Install shorter valve stems. 2. Remove stock pads and cut "roller shares" "Mickey mouse ears" off. These are weights to avoid pad noise. I cut mine off when the car was new an did not notice any increase in NVH 3. Replace stock pass with aftermarket. I don't recommend this as the stock pads a Ferodo 1000 material that is very very good. I ran them on the track for a year and they where great. Matt
11-19-2015, 11:23 AM | #10 | |
I'm interested in 1., but House of Wheels sent me the rubber instead of metal stemmed TPMS. Not sure the metal ones are any shorter. Would need a side by side comparison to tell and the metal TPMS stemmed ones couldn't be tucked down like we did with these rubber ones if they were not. I was thinking maybe the rubber onese could be shortened somehow by removing a section of length out of the straight section of the rubberized stem itself (say 1/4 to 3/8") and re-sectioning with some threaded tubing...either internally threaded like the valve core threading...or externally threaded like the cap threads with a die??? Or just get 2 shorter rubber stems for the fronts if they exist for some other GM application. Last edited by bub; 11-21-2015 at 10:53 AM. |
11-19-2015, 03:17 PM | #11 |
2013 Silver 1LE
Drives: 2013 1LE/ G6X3 cam/corsa exhaust. Join Date: Feb 2015
MRR wheels
I installed my about six months ago, and no issues yet. I have the billet stems.
11-19-2015, 09:30 PM | #12 | |
Also curious about clearances after the pads wear and the roller skates translate inward towards rotor due to the pad wear... What a crappy location for a valve stem...right on line with the caliper, and in our case right in line with the outboard pad's "roller skates" balance counter weights |
11-20-2015, 08:32 AM | #13 |
2013 Silver 1LE
MRR wheels
I got this pic, hope it helps you out.
11-20-2015, 09:12 AM | #14 |
High-tech Redneck
Drives: '10 CGM SS, '02 2500HD, '09 300SRT8 Join Date: Nov 2010
I value your opinion, so your statement also implies that stock SS wheels are also not something we should be tracking with using the same logic. I recognize and support the forged vs cast discussion under the substantial loads expected on track days and also recognize the decision of GM to go to forged or all "track-centric" models. With the MRR certifications on the 228's, do you not agree that they are equal to the stock SS wheels?
"My friends call me Chris. Are you my friend?"
2010 CGM L99 2SS/RS - GPI SS3 VVT, BTR DoD Delete, Circle D 4c, BTR springs, Katech C5R Timing Chain, MRR-228 315/275, CAI, Elite catch-can, TSP 1 7/8" Headers + offroad pipes, Magnaflow 3", Pfadt springs, BMR LCAs, toelinks, trailing arms, cradle bushings, & sway bars w/ endlinks, Vitesse paddles, heritage grille, and an eBay splitter. Power upgrades by Race Proven Perf.; Tuning by ShorTuning. |
