TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LFX Engine, Exhaust, and Bolt-Ons
Old 10-26-2015, 03:43 AM   #1
xRedsox
Night Fury
xRedsox's Avatar
Drives: 2016 Golf R
Rev surging and higher idle
I started my Camaro and for some reason it started randomly rev surging up past 1000RPM and even a little past that and then after a few surges it calmed down and sat at an higher than usual idle and would go up and down. I had a CEL so I went Autozone to see what the codes I was getting. Something with the crank sensor not being aligned with the camshaft sensor and intake sensor and exhaust sensor. I am tuned, but the only changed to the engine were timing. Anybody have an idea of what might be wrong here?
2014 2LT RS A6
Mods: K&N Intake, Magnaflow Axleback, BMR Strut Tower Brace, VTC Throttle Controller, Tune.
xRedsox is offline   Reply With Quote
Old 10-26-2015, 04:11 PM   #2
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
Could you reload the stock tune to see if that fixes the issue?
http://www.obd-codes.com/p0018
Power is worthless without control. The 2nd protects the 1st.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 10-27-2015, 10:20 PM   #3
xRedsox
Night Fury
xRedsox's Avatar
Drives: 2016 Golf R
Stock tune on and the codes still show up, I'm guessing the sensors went whack and got damaged trying to fix a problem that wasn't happening.
Also, my car when I am at a stop light would slow rev down and shake like it is going to stall then rev itself back up. I am in an automatic so its strange.
2014 2LT RS A6
