09-28-2015, 02:29 AM | #1 |
Drives: 2017 1SS M6 NPP Join Date: Aug 2015
Skip Shift Eliminator advise please (where to buy one)
I need one of these badly. I see that Phastek, and Apex sells them but at a pretty high cost for a dummy plug. eBay/Amazon has them for much less, however I don't know if they are good or not? Anybody ever use one off eBay etc.?
Does it also affect the reverse lock out? Any issues when using these things? Any advise would be great....Thanks |
09-28-2015, 05:11 AM | #2 |
Drives: 2010 1SS Join Date: Aug 2015
No issues with reverse lockout as I understand they are separate features but have not attempted any tests myself.. LOL..
If you plan to get a tuner you can do it through that also so you don't need the physical eliminator.. But I did get one off e-bay and it was the same as you will find just less but do go with a good seller if you go that route or choose a known elsewhere. It is a must mod one way or another |
09-28-2015, 05:42 AM | #3 |
Drives: 2010 2SS/RS Inferno Orange Join Date: Mar 2013
I picked mine up from APEX a few years back and I'm happy with it. It was worth the $25 for me.
U.S. Army Retired |
09-28-2015, 05:56 AM | #4 |
I would recommend apex. They contribute a lot to the site and have great customer service. If you buy a cheapy it may work for a while but cheap electrical contacts may lead to corrosion over time. It's still cheaper to buy one good once than to buy 2 or more cheap ones.
Whipple S/C,Kaotik cam, Kooks/Magnaflow exhaust,Alpine/JL Audio
09-28-2015, 06:15 AM | #5 |
Drives: 2014 2SS/RS Join Date: Dec 2014
While waiting for the device to arrive ... when the "1 to 4" shift indicator appears you can actually do "1 to 3" instead; it does not block third gear.
The skip shift eliminator simply has a single resistor (2,200 ohm - costs about a dollar - mine is 1 watt, that is plenty) across the connector terminals that plugs in to the two wires leading to the bypass solenoid. That resistor tricks the car in to thinking the wires are still attached to the bypass solenoid (places a small load on the circuit) so it will not throw a code after the solenoid is disconnected from the circuit. It will not affect the reverse lock out solenoid. I'd recommend double-checking whichever one you buy with an ohm meter to make sure resistance value is within specs before hooking it up (or build it yourself). Ron Last edited by ron123; 09-28-2015 at 06:37 AM. |
09-28-2015, 07:55 AM | #6 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
Paid around $13 for one off ebay for my 2010 SS and same for the ZL1. High quality pieces. Never had an issue with either one. I recommend doing this. Forget all that leave it in first or shifting to other gears. Make the car do what you want it to do, not the other way around.
09-28-2015, 07:56 AM | #7 | ||
Drives: 2000 Camaro SS Join Date: Feb 2010
09-28-2015, 08:16 AM | #8 |
Drives: 2018 1SS M6 Join Date: Nov 2014
The skip shift is rpm based. I just learned to drive around it. Hold first a little longer, or shift to second a little sooner depending on which is more appropriate. On the rare occasion I do get caught in it, I just shift down to 4 then up to third in one motion if traffic is starting to move, or I just hold the clutch in a tick longer and shift to second. But, hey, people make a living building and selling these things, they need to eat too.
09-28-2015, 09:17 AM | #9 |
Drives: 2014 Camaro SS Join Date: Sep 2013
Just get your car tuned dude. It'll save you a few bucks if you just get your tuner to do it.
09-28-2015, 09:49 AM | #10 |
Drives: 2014 Summit White 2SS/RS M6 Join Date: Aug 2012
tuning your car will void the warranty , right?
09-28-2015, 10:01 AM | #11 |
Older Than Dirt
Drives: 2010 & 2013 Camaros Join Date: Apr 2010
Technically, yes. Practically, the chances of getting "caught" by the dealership are slim. But the possibility is real.
I ended up with a Hurst brand skip shift eliminator harness, but I'm guessing it's the same as all the others. I would recommend a plug-n-play harness style over the resistor plugged onto the end, and the only reason why is that you maintain the water-resistant plugs on either end to keep water from corroding anything within the plugs. Does the same thing but you protect your plugs better using the harness. And unless anyone is really looking, may not even notice it. On the ZL1, I've had that dang hill assist get me more times than the 1-4 shift solenoid ever did though. And I've got a fix for that too, if I ever find time to take out the console to get to that sensor.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
09-28-2015, 10:03 AM | #12 |
Drives: 2011 Summit White Camaro SS (LS3) Join Date: Sep 2014
You're driving too softly. I never have an issue in my car. Give it more throttle man! Perhaps the Vitesse Throttle Controller is giving me a hand as well
09-28-2015, 10:05 AM | #13 |
It will not outright void your warranty. If your car is tuned and one of your windows stop rolling up it will have no impact. However, if you have a catastrophic drive train problem, the service tech is required to forward a copy of your ECM info to GM. If it has been modified they will refuse the claim to cover it under warranty and you will be on the hook for a big repair bill.
09-28-2015, 11:01 AM | #14 | |
