Old 09-11-2015, 05:04 PM   #1
MrImSoFly
MrImSoFly's Avatar
Drives: 2017 Hyper Blue 2SS
15 Facts You Probably Don’t Know About 2016 Camaro (w/ underside pic of NPP exhaust)
http://www.hotrod.com/features/1509-...e-2016-camaro/
Found an article that might include information that people did not know about.
Happy Friday.
Chevrolet invited us to drive the 2016 Camaro on some scenic roads outside of Detroit and see what the all-new sixth-generation car was all about. We can’t tell you what it’s like behind the wheel just yet, but we can share some interesting tidbits about the car from speaking with Aaron Link, Camaro Lead Development Engineer, as we inspected a 2016 Camaro SS that had been tilted on its side to show off its new suspension and chassis.
Much of the floor stampings are similar to the Cadillac ATS coupe, which shares the Camaro’s Alpha platform, but there were a lot of changes made during the Camaro’s development. For example, the suspension cradles could swap between the two, although the suspension links are longer on the Camaro because of its increased track width. The upper camber link and the toe link were repositioned accordingly. The Camaro uses more caster, partly due to the longer wheelbase that allowed engineers to kick the strut forward at the bottom. Caster curves are also improved over the fifth-generation Camaro
One part that’s directly shared is the shear plate that’s the same piece found on the Cadillac ATS-V. It’s the yoke-shaped part that ties the rocker panels together. It’s made from aluminum stampings and extrusions welded to form a single piece with a thick cross section.
The huge transverse muffler is divided in two internally for each bank of the engine. The four exhaust tips are only found on the optional NPP exhaust. It uses a butterfly valve that can either let the exhaust flow through unobstructed, or detour through the muffler. Tour mode lets the LT1 come to live at full volume at startup, then closes for quiet cruising. In Sport and Track mode it’s open all the time while Snow/Ice Mode leaves it closed all the time.
Although the 2015 Camaro also had a 3.6L V6, the 335hp 3.6L powerplant is a new design for the sixth-gen. It uses a larger bore and a shorter stroke than the last 3.6L and it’s the first application of Active Fuel Management in a V6 Camaro, meaning the 3.6L will run as a V4 during light throttle operation, just like the LT1 V8.
Because the exhaust gas volume is reduced when only running four cylinders, the Camaro uses a valve in the exhaust to increase backpressure. Here’s the valve on an LT1-equipped SS.
The smaller of the two new differentials on the sixth-generation Camaro is used on all four-cylinder models and the 6-cylinder automatic transmission models. It is shared with the new, full-size Cadillac CT6 and uses a 200mm ring gear. The housing is cast iron and the side plate is cast aluminum.
V6 manual cars and all V8 models get larger half shafts , a 225mm ring gear, and a cast iron side plate. “For noise and vibration it really is superior. If just cleans up the traditional diff noise we don’t want.”
Differential cooling is standard on the SS. It uses an oil-to-oil cooler that runs transmission fluid through a heat exchanger that’s submerged in the differential oil. It’s the same transmission fluid whether it’s the six-speed manual or the eight-speed automatic. Yep, Tremec manual transmissions use automatic transmission fluid.
All manual trans cars and all SS Camaros use a clutch-style limited slip. The four and six-cylinder autos use an open differential.
Manual trans LT1 cars use a 3.73:1 ring and pinion, autos get 2.77:1 because of the low 4.56 first gear in the 8L90. The final drive ratio with the automatic is just slightly lower than it would be if it were equipped with a 1960s-era Turbo 350 and a 4.11:1 ring and pinion. Expect some solid acceleration times.
The 3.6L and 6.2L pipe induction noise from the intake plumbing upstream of the throttle body through a diaphragm and right up to the firewall. Here’s the LT1 engine bay and if you look below the intake duct you can see the “kazoo” that routes induction sound toward the cockpit.
The four-cylinder uses and active system to enhance engine sounds through the stereo. Camaro lead engineer Aaron Link told us it can be turned off. “We’re not trying to make it sound like a V12, it just fills in holes that a turbo can muffle sometimes. You can hear the turbocharger in the 2.0L engine. “Especially windows down, you can hear it chirp.”
The transmission cooler is on the same plane as the road surface. The lip on the leading edge of the transmission cooler opening causes a low-pressure area to help draw air through.
Because the Alpha platform is narrower, Camaro engineers split the engine cooling between three radiators. One is mounted in the traditional location and uses an 850-watt electric fan. Two outboard radiators are canted inboard and fed high-pressure air from the outer edges of the center lower grille opening.
The Camaro engineers call the contour of the Camaro’s roof a “reverse Mohawk”. If you opt for sunroof the panel is smooth instead.
MrImSoFly is offline   Reply With Quote
Old 09-11-2015, 05:28 PM   #2
bhavyas
bhavyas's Avatar
Drives: 2016 1SS Yellow
Wow!!! I didnt know the quad tips are only with the NPP... anyways I was going to opt for it... it seems the writer was pretty impressed with the acceleration times..
bhavyas is offline   Reply With Quote
Old 09-11-2015, 05:33 PM   #3
13vertss
13vertss's Avatar
Drives: 2013 Camaro convertible 2SS/RS
The article also confirmed the the LSD is in both Auto and stick in the SS.
13vertss is offline   Reply With Quote
Old 09-11-2015, 05:44 PM   #4
YellowFin
YellowFin's Avatar
Drives: 2016 Colorado Z71
A good read from a reliable source. Thanks for sharing.
Previous Camaros:
1987 Camaro Sport Coupe V8
2002 Camaro SS Convertible
2010 Camaro SS
Current:
2016 Chevy Colorado 4X4 Z71 in black
2016 Chevy Camaro 2SS in red
YellowFin is offline   Reply With Quote
Old 09-11-2015, 05:52 PM   #5
Jeffro19
Jeffro19's Avatar
Nice read. A lot of shots of the underneath which is nice!
Old 09-11-2015, 05:53 PM   #6
cyberbro
cyberbro's Avatar
Drives: Not a Camaro at this time
Thats some final drive ratio on the auto, that thing is going to pull hard.
Order Status:
2000 8/27/15
3000 9/3/15
2000 9/22/15 (Order changed)
2016 2SS With Auto, NPP, MRC, Nav, Split 5 Spoke Bright Aluminum.
cyberbro is offline   Reply With Quote
Old 09-11-2015, 06:32 PM   #7
Bhobbs
Bhobbs's Avatar
This should put to rest any beliefs that the Camaro is based on the CTS version of the Alpha.
Old 09-11-2015, 06:44 PM   #8
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
Check it out! Hotrod.com just posted 15 facts (most of which is new info or confirmed info we needed) http://www.hotrod.com/features/1509-...e-2016-camaro/
Sledgehammer70 is offline   Reply With Quote
Old 09-11-2015, 06:46 PM   #9
Sledgehammer70
Lethal Camaro
A lot of cool info here... also the first pic of the undercarriage. Looks clean and streamlined compared to the 5th gen SS.
Old 09-11-2015, 07:21 PM   #10
MemBluff23
Drives: 19 Camaro SS
Nice Article and good pics
MemBluff23 is offline   Reply With Quote
Old 09-11-2015, 07:39 PM   #11
13vertss
13vertss's Avatar
Can anyone get a close up of the charts?
Old 09-11-2015, 07:58 PM   #12
'01LS1
Drives: 2003 Pete
I already want to know what it sounds like with the exhaust valves gone along with that monster muffler. Know some of the GM truck guys cut that stuff off & replaced with straight pipe.
I know the reason the valves are there for both back pressure & drone. But am still curious.
'01LS1 is offline   Reply With Quote
Old 09-11-2015, 08:29 PM   #13
Jakey2SS
Drives: 15' Scat Pack
why must they give us gigantic mufflers!! hopefully this is only for
the auto guys lol
Jakey2SS is offline   Reply With Quote
Old 09-11-2015, 08:42 PM   #14
DenverTaco07
DenverTaco07's Avatar
Nice, thanks for posting.
Like how they described the muffler.
