Old 08-30-2015, 05:53 PM   #1
13vertss
13vertss's Avatar
Drives: 2013 Camaro convertible 2SS/RS
6th gen Camaro brake size info - from Brembo site
Got this on Brembo's web site. More detail.
Chevrolet Camaro
Italian brakes do it better
The Chevrolet Camaro Coupe is 90 kg lighter than the previous models with better aerodynamics and brakes.
The Brembo four-piston, two-piece aluminium calipers are designed specifically for weight savings and are among the stiffest available with virtually no distortion from high thermal and torque loads, even under the most demanding conditions. Brembo’s corrosion-resistant calipers in anodized aluminium offer reduced weight over traditional calipers.
On the Camaro LT, the available Brembo brakes include 12.6-inch (321x30mm) front rotors with four-piston aluminium calipers. Camaro SS employs 13.6-inch (345x30 mm) front rotors with four-piston aluminium calipers and 13.3-inch (339x26 mm) rear rotors with four-piston calipers.
13vertss is offline   Reply With Quote
Old 08-30-2015, 07:03 PM   #2
cyberbro
cyberbro's Avatar
Drives: Not a Camaro at this time
Fist time I have seen a size for the rotors
Order Status:
2000 8/27/15
3000 9/3/15
2000 9/22/15 (Order changed)
2016 2SS With Auto, NPP, MRC, Nav, Split 5 Spoke Bright Aluminum.
cyberbro is offline   Reply With Quote
Old 08-30-2015, 07:08 PM   #3
13vertss
13vertss's Avatar
The part that got me is, Brembo says the new Camaro IS 90 kg less then previous model, which is near 199lbs.
Old 08-30-2015, 07:10 PM   #4
GMGP5X
GMGP5X's Avatar
Drives: 2011 2LT RS VR 2008 Silverado 2500
90 KG is 198 LBS Guess Al O. was right!
2LT RS VR / ARK DTS Cat back exhaust / Roto-Fab CAI / RPI stealth mud guards /Defender works billet chrome door sills/ DIY painted engine cover, trunk corners, and brake rotors / RX catch can / Team LLT badges. Team LLT
GMGP5X is offline   Reply With Quote
Old 08-30-2015, 07:25 PM   #5
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
Considering how heavy 4 corner 6 piston Brembo brakes were for Gen 5. Not shocking 4 piston ones save this much weight.
Sledgehammer70 is offline   Reply With Quote
Old 08-30-2015, 07:30 PM   #6
13vertss
13vertss's Avatar
5th gen only had 4 piston, but the rotors were larger due to weight.
Old 08-30-2015, 07:39 PM   #7
Sledgehammer70
Lethal Camaro
You could upgrade to a set of 6 piston calipers just like you can now for 2016. Same ones from the ZL1.
The above statement doesn't really outline what option the 5th gen had to get to their est. of weight savings.
Old 08-30-2015, 07:40 PM   #8
Blackdevil77
Blackdevil77's Avatar
Drives: 2008 Pontiac G8 GT, Shelby GT500
Are 6 piston brakes an option on the SS, or 4 piston is as big as it gets? I remember reading somewhere that 6 piston were available. Maybe the car simply doesn't need 6 piston brakes with the reduced weight.
Blackdevil77 is offline   Reply With Quote
Old 08-30-2015, 07:42 PM   #9
Sledgehammer70
Lethal Camaro
The 6 piston upgrade on the 5th gen was almost a $5k upgrade. But yes, they are available for the 2016 SS.
Old 08-30-2015, 08:51 PM   #10
toehead93
Drives: 2014 2SS/1LE
The 5th gen was a dealer installed option not a factory option so I suspect pricing to be much better.
Used Racing Brake 2 Peice Rotors for sale:
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 08-30-2015, 09:24 PM   #11
jaymsu
Yeti's Daddy
jaymsu's Avatar
Drives: ATS-V, Prowler, M6 V10
It will be dealer install option on 6th Gen as well, so price will be pretty high like it was with 5th gen.
jaymsu is offline   Reply With Quote
Old 08-30-2015, 11:20 PM   #12
VF-22
Drives: 4 Wheels
So what's the replacement cost when they wear down on these Brembo's that come standard on the SS?
VF-22 is offline   Reply With Quote
Old 08-31-2015, 06:17 AM   #13
jaymsu
Yeti's Daddy
jaymsu's Avatar
Are you talking about brake pads? If you don't need race pads and don't want expensive OEM pads, I'm sure there will be many inexpensive aftermarket options for you, before your pads wear out.
If you want to replace 4 piston calipers to 6 piston, that would be about 4k, but unless you track your car hard, you won't have to replace the calipers, so all you need to worry about is the pads.
Old 08-31-2015, 09:55 AM   #14
VF-22
Drives: 4 Wheels
Yah was talking pads...would never track it so 4 piston would be just fine. Thanks!
