08-21-2015, 01:19 PM | #1 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
1000bhp Z/28!
Impressive....
https://youtu.be/n6FgHthhfH0 HPE1000 Supercharged Upgrade Available for the 2014 - 2015 Chevrolet Camaro Z/28 Power: 1000 bhp @ 6,300 rpm Performance: 0-60: 3.1 sec. 1/4 mile: 10.4 @ 136 mph Supercharged HPE1000 Upgrade Includes: 2.9 Liter Supercharger System Forged Pistons Forged Steel Rods Custom HPE Camshaft Ported Cylinder Heads Upgraded Fuel Injectors Upgraded Fuel System High Flow Intercooling System Intercooler Heat Exchanger Upgrade Long-tube Stainless Steel Headers Stainless Steel Midpipes High Flow Catalytic Converters All Necessary Gaskets & Fluids Professional Installation HPE Engine Management Calibration Dyno Tuning & Road Testing Serial-Numbered Dash & Engine Plaques Hennessey Exterior Badging Hennessey Premium Floormats 1 Year / 12,000 Mile Limited Warranty
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
08-21-2015, 01:45 PM | #2 |
Drives: 14 1le Join Date: May 2012
Nice!
06 gto Maggie 489 rwhp sold
05 gto ERL/HKE 454 609rwhp na sold 06 Z06 500 rwhp sold 10 2ss ERL 427 530 rwhp sold 14 1ss 1le |
08-21-2015, 01:55 PM | #3 |
Lets roll...
Drives: 14' Join Date: Jun 2014
As much as I love the z28, that is a horrible et and trap for 1000hp.
08-21-2015, 02:00 PM | #4 | |
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
1000bhp prob dyno 800ish at the wheels, seems about right et and trap wise
08-21-2015, 02:48 PM | #5 |
Lets roll...
That car should be putting mid to high eight-hundred HP to the tire. Should be a bottom 10 sec with 140+ trap.
Hopefully it was tested on a hot&humid Texas summer day.
08-21-2015, 03:01 PM | #6 |
Drives: 2014 Camaro Z28 Join Date: Jan 2015
This could explain the slower trap speed:
GM speaking of the Z28: "Numerous modifications were made to the exterior, compared to the Camaro SS, with new and revised content developed to improve aerodynamics,.... They help the Z/28 produce 440 pounds more downforce at 150 mph, relative to the SS, which generates slight lift at that speed." Not sure how the comparison goes from the SS to the ZL1, but I assume it's similar. And "lift" (negative weight) versus "downforce" (positive weight) could be a tremendous factor. The z28 could effectively be 500-600lbs heavier at speed. The rolling resistance of those 305's at all corners probably plays a part too. |
08-21-2015, 03:05 PM | #7 |
Drives: 2010 SS L99 IOM Join Date: Aug 2012
369rwhp/392rwtq
"Spending money I don't have, to buy parts I don't need, to impress people I don't know!" -Jenkins |
08-21-2015, 04:38 PM | #8 |
HAMMER PILOT
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado Join Date: Nov 2011
I didn't see any rear end mods. If it was built for the 1/4 mile GM said the rear end wasn't built for multiple hard launches.
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
08-21-2015, 05:08 PM | #9 |
Yeah...it gave me a semi to read about it, but the small ring & pinion is going to break apart if there is a hard launch. Wheel hop will also kill the rear with that much HP. I bet the cost will make one gag!
08-22-2015, 10:16 AM | #10 | |
Snake Eater
Drives: 2012 AGM ZL1 Join Date: Oct 2011
Build Thread: http://www.camaro5.com/forums/showth...95#post8351295
Make sure you dont forget to subscribe to my channel! More content on the way. Like, share with your friends https://www.youtube.com/channel/UC9Z...sP2wjsLLFeP1zQ Follow me on instagram: http://www.instagram.com/snkeatr/ |
08-22-2015, 06:28 PM | #11 |
Drives: 2014 camaro Z/28 Join Date: Jul 2014
That car should run Mid 9's at over 140mph. My 4500lb dodge challenger SRT making 750 rwhp runs 9.90's at 135
2014 Camaro Z/28 #85
2015 Jeep Wrangler Unlimited Rubicon Hard Rock 2009 Dodge Challenger SRT 8 1000 hp Arrington 426 hemi Pro Charger F1 13psi Fore precision works billet fuel rails Triple walbro fore fuel pump Moper hemi fuel Injectors stage 2 70lbs ATI super damper Southern Hotrod trans NAG1 D 3000 stall converter DSS 1400 HP axles DSS Drive Shaft American racing headers w/high flow cats Magnaflow cat-back competition exhaust Eibach Pro-Street-S kit adjustable coil overs Razors edge strut tower brace 4 point rear strut tower brace Matrix subframe brace ACE wheels 22x10.5 and 22x 9. |
08-22-2015, 06:42 PM | #12 |
H-Town Camaro Club
Drives: 2013 Dusk Edition 2SS/M6/Sun/NPP Join Date: May 2014
A fool and his money are soon parted. If you want a quality honest build from a shop that will treat you right, this isn't it.
08-23-2015, 01:01 PM | #13 | |
Drives: 2013 Camaro ZL1 Join Date: Dec 2012
I believe there is an old thread on that topic. The ZL1 has more downforce than the SS if I can recall correctly due to the front end splitter with side wings and hood extractor. They just didn't install some panels and say it looks good. |
08-23-2015, 01:31 PM | #14 |
Drives: 2015 Z/28 Join Date: Jun 2015
I'm no engine wizard, but for $80K even I could put together *several* 1000HP motors. This is just badge engineering...
