Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 07-13-2015, 09:08 PM   #1
91Zman
91Zman's Avatar
Drives: '13 1SS/RS IOM white stripes
Will putting a taller sidewalled tire on the stock wheels
hurt the performance of my SS? ...and if not then what tire size?
91Zman is offline   Reply With Quote
Old 07-13-2015, 10:20 PM   #2
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
I wouldn't go taller on the sidewall than what it comes with stock, it's already a 40 series in the back and a 45 series up front.
If anything i'd use a smaller sidewall tire.
What are you trying to accomplish? Less fender gap? If that's the case I would go with some 1" lowering springs to get the look you want.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 07-13-2015, 10:42 PM   #3
91Zman
91Zman's Avatar
actually better ride comfort quality.
should i just go for a better brand than stock Pirellis.the roads over here are terrible.
Old 07-13-2015, 11:03 PM   #4
SS PANTHER
SS PANTHER's Avatar
Drives: 2013 SS Supercharged Convertible
Try some Nitto Invos. Soft sidewall and quiet ride. Not great for handling, i.e.; AutoX or road course.
SS PANTHER is offline   Reply With Quote
Old 07-13-2015, 11:08 PM   #5
thunderkyss
Drives: 2015 Red Hot SS/RS M6
The fronts on our 20" wheels are 245/45 (245mm wide, the height is 45% of that width or 110mm off the rim... there's 25.5mm to an inch, so that tire sits 4.3" off the rim)
I think it would be hard to find a performance tire in a 60 or 65 series. Sounds like a truck tire.
But I get where you're coming from. You can get a set of BC Racing coil overs for the cost of a nice set of tires... you might want to try that.
thunderkyss is offline   Reply With Quote
Old 07-13-2015, 11:30 PM   #6
Brandon_Lutz
Brandon_Lutz's Avatar
Drives: 2012 Inferno Orange 1SS/RS
Louisiana roads will chew up our stock Pirelli's and spit them out. I just replaced mine with BFG G-Force Sport Comp 2's when I got my new wheels and I couldn't be happier. They have a longer tread life rating and so far I like the ride of them better than my stock tires.
My Pirelli's barely lasted 18K before they were shot. They grip well but being so soft coupled with our crappy roads and they get ate up quickly. Especially if you do some spirited driving. While the BFG's are also a summer only tire, they are a little bit tougher than the P-Zero's.
Brandon_Lutz is offline   Reply With Quote
Old 07-14-2015, 07:45 AM   #7
Destructo09
Try the Continental DW tires or DWS if you need an all season, the DW's ride quite well, my brother has them on his car, 275/40R20s all around. Also, the DW's grip quite well also, likely better than P-Zeros.
2010 2SS
BMR 1" Springs
1LE rear sway bar
SRP Racing Pedals
K&N Typhoon CAI
Old 07-14-2015, 10:30 AM   #8
Rudy@Tirerack
Rudy@Tirerack's Avatar
Drives: 1-800-428-8355 X4664
Taller sidewalls will create less handling responsive handling. If you get the diameters off front and rear it can also cause traction control/ABS issues.
I also like the Continentals The DWS would have a slightly better ride versus the DW.
Rudy@Tirerack is offline   Reply With Quote
