Old 07-11-2015, 02:14 PM   #1
BigRedViking
BigRedViking's Avatar
Drives: 1987 IROC-Z 5.7L 2016 1SS M6 NGM
Send a message via Yahoo to BigRedViking
2016 SS has three radiators
Seems unnecessarily complex. Hopefully they're well protected in the event of an accident. If one gets damaged does all the engine coolant leak out?
BigRedViking is offline   Reply With Quote
Old 07-11-2015, 02:24 PM   #2
Waiting46
Drives: 1981 silver corvette,Hyper Blue 2SS
its just a little tubing, nothing crazy
Waiting46 is offline   Reply With Quote
Old 07-11-2015, 02:35 PM   #3
fastball
Drives: 2017 Camaro 2SS 6MT
It's for better cooling when the car is at the track. Similar to the Corvette cooling system. When you are hitting corners quickly the extra radiators provide cooling when there is no air coming straight ahead into the front grille.
If one gets damaged yeah the coolant will probably leak out. But it's like that with any car. You damage the radiator, the coolant leaks.
Don't worry. Be happy there is a high capacity cooling system.
fastball is offline   Reply With Quote
Old 07-11-2015, 02:47 PM   #4
IOMike
Drives: 2022 F150, 87 Monte Carlo
Shit breaks in an accident anyways, I don't see the difference.
Overbuilding a car is not a bad thing.
IOMike is offline   Reply With Quote
Old 07-11-2015, 02:50 PM   #5
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
How is that any worse than a single large radiator getting damaged & leaking out coolant?
But beyond that, wouldn't having 1 'medium' central radiator with 2 smaller ones mounted at right angles to the main, kinda like this: [, expose less radiator area to potential damage?
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 07-11-2015, 02:53 PM   #6
ULTRAZLS1
ULTRAZLS1's Avatar
Haven't you guys heard ? It's bad engineering and a band aid.
Old 07-11-2015, 03:08 PM   #7
hotlap
hotlap's Avatar
The base SS is a serious machine
10. The SS model is "track capable"
In anticipation of expected hard driving, the Camaro SS is rated as track capable. That means that it can run for an entire tank of fuel at maximum speed around GM’s Milford Road Course without cooking its engine, transmission, differential, or brakes. That’s why it has so many radiators.
http://www.caranddriver.com/flipbook...-new-camaro#11
Ronald Reagan -
Old 07-11-2015, 03:19 PM   #8
BigRedViking
I was not aware of the position they are mounted. Longitudinal mount would create a smaller target. I'm cool with that
Old 07-11-2015, 03:32 PM   #9
DGthe3
Moderator.ca
DGthe3's Avatar
Another insight from that Mustang site?
Old 07-11-2015, 03:38 PM   #10
ULTRAZLS1
ULTRAZLS1's Avatar
Of course
Old 07-11-2015, 03:49 PM   #11
Jeffro19
Jeffro19's Avatar
Isn't the 3 radiators for 3 different components? One for engine, trans and oil? Maybe 3rd one is rear end oil? If so, many vehicles have these type of radiators already at least the trans and coolant radiator.
Old 07-11-2015, 04:02 PM   #12
hotlap
hotlap's Avatar
No. The engine and transmission have different coolers
Ronald Reagan -
Old 07-11-2015, 04:05 PM   #13
Jeffro19
Jeffro19's Avatar
Yes that's what I meant each one is for a different component. One for the engine, one for the trans and one for rear end. Most cars and trucks now already have separate radiators or coolers for engine and trans
Old 07-11-2015, 04:34 PM   #14
khell86
Drives: 2012 Ford Focus
Does the c7 corvette use 3 radiators?
khell86 is offline   Reply With Quote
