06-10-2015, 07:25 PM | #1 |
Drives: 2015 2SS/RS vert, Spring Green Edtn Join Date: Jun 2014
Shopping for a Swirl Finder Light
I'm shopping around for a swirl finder in the $50.00 or under range, and had my heart set on the Brinkman Maxfire Dual Xenon Spotlight, but it's on back order everywhere I've checked, and I've read elsewhere that it's been discontinued.
It looks like they've replaced that with an LED model, the Brinkmann 800-2280-0 Tuff Max LED Spotlight. Has anyone tried this one, or can you suggest another one in my price range?
2015 2SS/RS vert, Spring Edition Green Flash (2015 - present)
2014 1LT vert, Blue Ray Metallic (2014 - 2015) |
06-10-2015, 08:17 PM | #2 |
I have the Flex and like it. It didn't come with any instructions, but I learned through use. 1 click high beam, 2 clicks low beam, 3 clicks strobe. It also has a beam size adjustment on top where you pull it out and push it in to get a wider or narrow beam. After you move it around you'll find the best position to see the swirls.
I have since purchasing found this light for a cheaper price by a company named Sarge, this is the exact same light. $29.99 instead of $44.99(Autogeek/Autopia) before shipping or discounts. http://www.sargeknives.com/store/LED...lashlight.html If you have overhead lighting in your garage, this light will not pick up swirls very well with the lights on as well, they need to be off. Last edited by Joe M 2012 2SS; 06-10-2015 at 08:38 PM. |
06-10-2015, 08:37 PM | #3 |
Is there anything that will work you can buy from Home Depot, Walmart, Auto Zone, etc....
06-10-2015, 08:43 PM | #4 |
I don't know of any, I looked at all the one's at Wal-Mart, and they didn't have one similar to this. I suppose you could buy one and try it out, if it doesn't work, take it back for a refund.
06-10-2015, 08:54 PM | #5 |
What makes these lights see the swirls? Is it the LED or is it because it is very bright?
06-10-2015, 09:03 PM | #6 |
06-10-2015, 09:23 PM | #7 | |
The light your looking at from HF is too bright. You can buy 500w Halogen shop lights on a stand which will work, the only drawback is they aren't handheld, they get hot when left on for a period of time, and moving them around to get the best view is a bit cumbersome. I had one of these (500w Halogen on stand) I got from Home Depot, I took it back after getting the handheld version. |
06-10-2015, 09:56 PM | #8 | |
http://www.amazon.com/dp/B008W1N6A0/...I2RXDQWI2S5XE2 For that price, even if it doesn't work as a swirl finder, it's still a great flashlight.
06-11-2015, 06:14 PM | #9 | |
That one should be fine, it's a little brighter at 180 vs 130 lumens, but the focus and high, low, strobe options are the same. My flex works better on darker colors, light colors like white, yellow, silver, the one's that typically hide swirls better are tougher to see, but adjusting it will give you a decent view on these types of base colors. |
06-11-2015, 08:20 PM | #10 |
Drives: 2015 Camaro RS 2LT AGM Join Date: Aug 2014
I got a FLEX and I still find it hard to find swirls or scratches....I don't know if it is the metallic in the paint or just me....the operator not able to see the defects. UGH I had high hopes.
2015 RS Camaro 2LT with Sunroof, Performance Exhaust, Ground Effects, Tinted Windows, LED Fog Lights(DD), CAI Cold Air Intake, Ghosted Side Markers(Showstopper), Elite Catch Can, Xpel & SunTek PPF, Replica Z28 High Wing Spoiler, ZL1 Replica Wheels(Satin Black Factory Reproductions) |
06-11-2015, 08:34 PM | #11 |
The reflection of the metallic flakes will make them harder to see, I'd try the lower beam and start with it narrow and move it out a little at a time. I recently did a "spot-fix" on a car with grey metallic and it was difficult to get it "just right".
06-11-2015, 09:55 PM | #12 |
Tri-County Camaro SWFL
I used the flashlight I carry for work. Maglite MagTac. 352 Lumen.....worked great
07-10-2016, 01:23 PM | #13 | |
Drives: 2010 2SS/RS M6 Black on Black Join Date: Jan 2010
It is a Coast HP7, and it was $39
Meh
07-10-2016, 09:26 PM | #14 |
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles. |
