dave@hennessey
Old 05-10-2015, 12:43 PM   #1
Nighthawk89
Nighthawk89's Avatar
Drives: 2011 Camaro 2Ss M6
Will 9 lb's Melt highflow's honeycomb's?
Anyone running over 600 to the wheels with HF cats?
Nighthawk89 is offline   Reply With Quote
Old 05-10-2015, 05:22 PM   #2
Rcfiddy1
Sold car...
Rcfiddy1's Avatar
Drives: 2010 Rally Yellow 2SS/RS #37115
Yes. Its all in the tune.
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust.
Rcfiddy1 is offline   Reply With Quote
Old 05-10-2015, 07:22 PM   #3
Nighthawk89
So thats a yes to you are running them or yes it will melt them?
Old 05-10-2015, 07:47 PM   #4
Rico
Flying da helicopter
Rico's Avatar
Drives: Black SS/RS
I have around 700 and after about 6 months I noticed it starting to melt.
Rico is offline   Reply With Quote
Old 05-10-2015, 08:26 PM   #5
Nighthawk89
Thats the kinda power im going for so i guess i better fork up the coin when i put my new corsa exhaust on.
Old 05-10-2015, 08:39 PM   #6
Rico
Rico's Avatar
Drives: Black SS/RS
For the moment I just gutted my cats, but I'm about to change them for straight midpipes.
Old 05-10-2015, 10:08 PM   #7
Nighthawk89
I thougjt about gutting them but i dont wanna waste a perfectly good extra set of HF's incase i ever need them..
Old 05-11-2015, 08:26 AM   #8
BooSSted
BooSSted's Avatar
Drives: 2017 Z06 / 2012 CTS
Doesn't Cali enforce the sniff test among other emission testing? I gutted mine just to past the visual check.
BooSSted is offline   Reply With Quote
Old 05-11-2015, 03:32 PM   #9
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Honestly the HP is a non issue.
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 05-11-2015, 05:46 PM   #10
2010SSRSM6
2010SSRSM6's Avatar
Drives: My wife crazy with my C5 usage.
Yes the cat's will melt. Mine melted with less than 600rwhp.
CA isn't using the sniffer on newer cars any more but their is a huge difference with and without cats in the smell. I had a local muffler shop make cat-less mid pipes for my system for $75.
UNDER CONSTRUCTION......again......
2010SSRSM6 is offline   Reply With Quote
Old 05-11-2015, 06:35 PM   #11
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
How is GM not melting them in the ZL1 and Z06 then?
franknbeans is offline   Reply With Quote
Old 05-11-2015, 07:49 PM   #12
Nighthawk89
Pretty valid point..
Old 05-11-2015, 07:49 PM   #13
Nighthawk89
How did your smog tests go this year?
No problems right brotha?
Old 05-11-2015, 07:51 PM   #14
1KillerSS
1KillerSS's Avatar
Build thread
