TireRack
Old 05-10-2015, 12:06 PM   #1
PurgeSS
PurgeSS's Avatar
Drives: 2010 Camaro 2SS, 2010 Tundra SR5
So these tire sensors..
Tire sensors keep going out of whack? Just hit 30k miles, and I went in to put some air in the left rear tire.. Reset the psi readings, and bam! Tire sensor light goes on, tells me it needs maintainance, and gives me "--" as readings for all 4 tires..
Is this a GM problem? As the sensors have gone out on the trucks I've or my family have owned.. I do have aftermarket tires.. F14's 20x9 & 20x10.5 rear.
2010 Camaro 2SS; BMR Strut Tower Brace, BMR Polyurethane Bushings, Pfadt 1.25" Drop Springs, Pfadt Front and Rear Sways, Pfadt Subframe Connectors, 1LE 3.91 Differential with Jannetty Racing Posi Mod, LMR Short Throw Shifter, Skip Shift Eliminator, LED's all around, SCE 102mm Throttle Body, Rx Catch Can, ACS Front Splitter and Side Rockers, Forgestar 20x9 w/ 275's Front and 20x10.5 w/ 315's Rear, NOW INSTALLED: Kooks long tube headers 1 7/8 w/ high flow cats, CAI, Jannetty Racing SCE tune.
PurgeSS is offline   Reply With Quote
Old 05-10-2015, 12:35 PM   #2
texsean
Drives: 2010 Camaro SS M6
Mine.. 2010 ms ss .. spent 3 weeks for rear sensors at dealer for this and they replaces both back sensors and 5 miles later it's back. Shut off car and sometimes it's fine. Annoying as hell.
texsean is offline   Reply With Quote
Old 05-10-2015, 04:03 PM   #3
13ashengrey
13ashengrey's Avatar
Drives: 2013 2SS Ashen Grey
The tire sensors only have a 6 year battery life and being a 2010 your pretty much there. When we have one come into our dealer over 6 years old we go ahead and put all 4 in. They are a little pricey though.
5.98 @ 115mph
13ashengrey is offline   Reply With Quote
Old 05-10-2015, 04:09 PM   #4
texsean
Explains why they did 2 not 4.. but the problem is still there on same wheels after they supposedly replaced them.. arg..
Old 05-10-2015, 04:28 PM   #5
Dfault
Dfault's Avatar
Drives: 2014 Camaro SS
You're not alone, I have been having this issue since I first bought my 2014. I just drive until they start reading again, it's annoying and I'll probably end up finding a way to tune it out.
Dfault is offline   Reply With Quote
Old 05-10-2015, 05:03 PM   #6
lawman007
Panama-Gulf War Vet
lawman007's Avatar
Drives: '11 SW 1LT/RS 6M
When you put air in the tire you DIDN"T need to reset the sensors. This resets all the sensors, also unnecessary. Believe me, the sensor will read the new pressure, that is how it is designed. If you change tires that is a different story, there's no way around that. You'll get the alarm immediately if you change the tire. Just keep trying to reset the sensors they will settle down after a few attempts.
Troy
lawman007 is offline   Reply With Quote
Old 05-10-2015, 05:08 PM   #7
Elykson
Custom One Off
Elykson's Avatar
Drives: 2010 Chicago Blackhawks Edition #1
When you hit the reset button, you have to let air out of all four tires, starting with the front left, and moving clockwise around the car. You let air out until the car horn beeps, then move to the next one. Then your readings will be set. Only works with the 2010, I believe.
Vararam Intake/SLP Loud Mouth II/BBK LT HFC/Magnaflow x-pipe/Pfadt Springs/Black Ice-olator/FE3 suspension/VMAX TB/RX catch can/Trifecta Tune
http://www.camaro5.com/forums/showthread.php?t=129416
Elykson is offline   Reply With Quote
Old 05-10-2015, 11:01 PM   #8
PurgeSS
PurgeSS's Avatar
Aha sounds a bit like a if you hop on one foot and rub your belly, but I'll try it and update what happens.
