dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LFX Engine, Exhaust, and Bolt-Ons
Old 04-30-2015, 08:16 PM   #1
cwb90
Drives: 2015 2SS Green Flash Edition
Best Performance Upgrades for around $500
New owner here of a 2014 1LT/RS. Have about $500 to spend and would like to know what would be the best performance upgrade or upgrades for around $500? Thanks.
cwb90 is offline   Reply With Quote
Old 04-30-2015, 08:29 PM   #2
hzisfrom1994
ZYJ
hzisfrom1994's Avatar
Drives: 2017 1SS Camaro/6 speed
I guess an intake ($300) with a throttle controller ($180) is the best performance upgrades for $500. However, I would do a exhaust upgrade and a catch can first. Catch can to better protect the engine, and the exhaust upgrade as when you hear a loud exhaust it will make you feel more power from the car lol!!
hzisfrom1994 is offline   Reply With Quote
Old 04-30-2015, 08:34 PM   #3
cwb90
Thanks for the suggestions. When you say intake, do mean the manifold or a cold air kit? Also, what purpose does the catch can serve?
Old 04-30-2015, 11:56 PM   #4
Jenner
Jenner's Avatar
Drives: 2012 SS/RS
I think he means cold air intake. The catch can keeps oil particles from entering and over time clogging up your intake valves.
Jenner is offline   Reply With Quote
Old 04-30-2015, 11:58 PM   #5
enzia35
Drives: '16 Garnet Red 1SS
Skip errything and just get the controller.
'16 Camaro 1SS
'18 Miata GT
Old 05-01-2015, 12:12 AM   #6
AnUnarmedMan
AnUnarmedMan's Avatar
Drives: 2013 LS
Controller for sure. Cold air intake and throttle body next
AnUnarmedMan is offline   Reply With Quote
Old 05-01-2015, 01:38 AM   #7
Mr Jos
Mr Jos's Avatar
Drives: '13 2LT RS
Catch can first as soon as possible. Saves some carbon cleaning in the long run (and these drink a lot of oil, I need to fill 2liters every 5000km). That's what I did. Then went with MRT v2.0 and Throttle controller soon after. I would say exhaust over VTC because the sound really puts a smile every time (The standard exhaust didn't do enough at all). VTC is very good, buts less 'smile' factor then exhaust roar, for me although. I still need to look for a CAI though. But perhaps I'll buy one when im in the States and take it with me home
Black '13 2LT RS
Thé only one 2013 LPG converted Camaro in the world
MRT V2, VTC
Mr Jos is offline   Reply With Quote
Old 05-01-2015, 05:43 AM   #8
Buschman
Buschman's Avatar
Drives: 2018 ZL1 2015 1SS 1LE
Catch can first. Then CAI and ported throttle body. Vitesse throttle controller, JacFab extendolator (intake spacer) and Ported intake manifold. Exhaust will only change the sound the factory set-up is pretty free flowing, just sounds like crap.
Talk to Chase from Apex he can hook you up with some great package deals. The JacFab stuff you need to get from Jason, they are both members here.
2018 ZL1
2015 1SS 1LE
Stock...ish
Buschman is offline   Reply With Quote
Old 05-01-2015, 08:46 AM   #9
rgrmoreira13
rgrmoreira13's Avatar
Drives: 2015 2SS 1LE
I think it should be a Catch can first and foremost. and then the road splits from there.
If you want a good exhaust note and less weight on your rear then get an exhaust. If you want a quick power gain then get a Cold Air Intake (The best in my opinion is Roto-Fab)
or even a PTB. 2 out of the 3 options you can do yourself so you save yourself labor $$.
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA
Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries)
Procharger D1x with a 3.85 pulley
ID1050x Injectors
Flex Fuel Sensor
Monster LT1 Twin Disk Clutch
Holley Sniper Efi Intake Manifold
NW 103mm Boosted TB
747rwhp at 12psi on E85
rgrmoreira13 is offline   Reply With Quote
Old 05-01-2015, 02:06 PM   #10
NYJets77
Drives: 2013 2LT/RS Summit White
If you get the CAI, get the Apex air scoop. Butt Dyno says "HELLS YEAH!"
NYJets77 is offline   Reply With Quote
Old 05-01-2015, 02:11 PM   #11
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
I suggest starting off with an intake system and an Elite Engineering catch can.
There are many good intakes, but the best ones are Airaid, CAI and Roto-Fab.
Feel free to call, PM or email me anytime with questions and I'll be happy to help get you setup.
Best regards,
Tyler
888-308-6007
JDP Sales is offline   Reply With Quote
Old 05-01-2015, 02:14 PM   #12
AKA-22
AKA-22's Avatar
Drives: ELLE-1
http://www.camaro5.com/forums/showthread.php?t=381244
AKA-22 is offline   Reply With Quote
