04-13-2015, 12:58 AM | #1 |
Vrrrm.
Drives: 2011 2SS/RS LS3 Join Date: Jun 2013
10.5 (315) rubbing what size to fix?
running a 10.5 wheel and even with nitto invo 315 (supposedly are running less wide the all others) I get rubbing on big bumps. I want to smaller size but what should i run?
04-13-2015, 01:17 AM | #2 |
Drives: 2010 2SS Join Date: Sep 2012
i think you may be limited by the rim offset and your drop....whats the offset and is it front or rear thats rubbing?
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
04-13-2015, 03:32 AM | #3 |
Vrrrm.
dont know offset how can i measure it
04-14-2015, 10:00 PM | #4 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
On the rear a 35 offset with a 10" rim works fine. So does a 10.5" rim
04-15-2015, 10:04 AM | #5 |
Vrrrm.
You mean a 35 rear offset will fit a nitto invo 315 or a Michelin PSS 315? PSS are quite a bit wider then invo.
My 10.5 is fitting just rubs on big bumps so i'd like to either measure my offset then shave it or buy a 305 tire thats about .3-.5 less of a width. so it clears.
04-15-2015, 10:06 AM | #6 |
So Cal Race Team
Drives: 2013 Camaro Join Date: Mar 2010
Why don't you try running a 3mm spacer on the rear, it might give you the extra clearance you need, as others have pointed out, the wheel offset is the issue.
04-15-2015, 10:09 AM | #7 | |
Vrrrm.
A spacer would make them stick out past the fenders.
04-15-2015, 10:27 AM | #8 |
Vrrrm.
http://i59.tinypic.com/289ilcn.jpg
As you can see the tire has a bulge i dont know why but when i measured the rear rims they where 10.5. The nitto invo is not (way to wide) just barely it actually clears no problem but oncei hit a big bump i hear it rub and the tire had a cut in the bulged area from hitting the innder fender. 1. who has a tire that runs about .3-.5 skinnier? nitto invo says there 315 is 12.4 wide? or 2. roll fenders or 3. figure out offset and shave the mounting surface to clear free up some room.
04-15-2015, 10:44 AM | #9 |
Svt lol
Drives: 2011 ss inferno orange blown Join Date: Jan 2012
I run a 11 inch wheel with 315 nitto tires lowered no issues.
plasti dip is not a mod.......and a cold air intake doesn't make you fast!
04-15-2015, 10:47 AM | #10 |
So Cal Race Team
If 3mm makes that big a difference, you're the dumbass for buying wheels with the wrong offset.
04-15-2015, 01:17 PM | #11 |
Drives: E92 BMW M3 Join Date: Oct 2012
Based on everything you have said I think you need to run a more narrow tire(305), or buy new wheels.
J-Rod Built and Matt@FSP Tuned |
04-15-2015, 01:20 PM | #12 |
Drives: 2013 2SS/RS/1LE Join Date: Apr 2010
04-15-2015, 01:32 PM | #13 |
2013 Camaro SS1LECTSVZ28
Drives: 2013 AGM 1SS/1LE Join Date: Nov 2012
You never stated the aspect ratio or rim size?
04-15-2015, 01:35 PM | #14 |
HAHA.....so true. At first I thought he wanted to stick with a 315, but a skinnier one than he has already tried.
