04-03-2015, 08:59 PM | #1 |
Z/28 at strip bone stock...yuck
I have had a lot of experience with many different cars at the drag strip. The Z/28 is possibly the worst car for the drag strip with the factory R comp tires. I did reduce the rear psi to 25 and did not try to adjust further. A burnout after getting the tires wet results in severe axle tramp and tire shake...problem 1. The car hates the drag strip typical launch and results in more axle tramp and more shaking which feels destructive...problem 2. The last thing I want to do is destroy a speciality rear end or snap an axle due to stupidity. I tried going around the burnout box also and doing a "clean off" scrub of the tires with worse results. I may try again with my ZL1 M/T drag radials instead of the Pirelli Trofeos. Some wouldn't post such an experience, but I felt it necessary. So, here is my best run which happened to be my first: The DA was +1600ft.
60' 2.1081 330 5.6665 1/8 8.5479@85.52 1/4 13.03@110.27 Traction control & stabilitrak were turned completely off. My other runs were aborted due to trials and tribulations...horrible tire shake & wheel hop. I may try again but this car isn't a drag car (duh). The car felt like a bucking bronco begging me not to ride(drive) it...lol! I'm not disappointed, but this car is going to take some patience and some more seat time to get decent e.t.s.
04-03-2015, 09:02 PM | #2 |
timeslip
04-03-2015, 09:03 PM | #3 |
Drives: 2010 2SS/RS L99 SLP Cosmetics Join Date: Sep 2014
Thanks for sharing. Just proves what we already knew deep down....IT AIN'T A DRAG CAR! It was born to corner!
On the bright side, you will now be NUMBER ONE, on the (all new) Stock, Z-28 Fast List!!!!!
13.244 @ 104.91 100% stock (#17).
Now - Mike Norris catch can. 245/50/19 Firestone Wingfoot A/S on LT2 black powder coated rims (square). 1 7/8" Speed-Engineering LTH, off road pipes, tune. Now 12.93 @ 109.13. |
04-03-2015, 09:22 PM | #4 |
Ha...fast list...no thanks! That e.t. is an embarrassment.
04-03-2015, 10:22 PM | #5 |
Drives: 2018 Camaro 1SS/1LE Join Date: Feb 2015
Your 60' is terrible. Get some drag radials. 110mph should be good enough for mid 12s easy.
04-03-2015, 10:36 PM | #6 |
Drives: Camaro ZL1 Join Date: Aug 2012
Damn hate to say it but told ya so. At least someone isn't scare to share it. Props for sharing. Not sure how the et is so bad, how were the shifts?
-2013 Camaro ZL1-Black Stripe Package-Ambient Light Kit-Subwoofer Package-Sunroof-Suede Package-NAV MYLINK-MANUAL BABY-Dual Vented Fenders-Exposed Carbon Fiber Insert
-Black 10 Spoke Wheels 604 RWHP 602 LBS/TQ |
04-04-2015, 01:53 AM | #7 |
Drives: 2015 z28 sold Join Date: Dec 2014
Shift points?
After dynoing my car found out it was better to shift at 6400 to 6500 rpm on the track...helped pick up some mph on the straight always. |
04-04-2015, 05:47 AM | #8 |
Shift points were in the 6600rpm range. I didn't try many different things because the launch proved to be so difficult. The shifting action is smooth as butter and have no complaints there. My e.t. was so bad because the 2.10 60' wasn't due to wheelspin...it was a slight bog and hesitation. One of my aborted runs due to starting line wheelspin and wheel hop was so annoying. After I let off due to initial wheel hop, I proceeded to go back to the throttle in the middle of 1st gear and the result was more wheel hop!! Frustrated, but not at all surprised. Please, someone else try and post your findings. My '87 Mustang GT in '87 on OEM Goodyear Gatorbacks was more forgiving!
04-04-2015, 06:07 AM | #9 |
Drives: 2023 ZLE Join Date: Jun 2009
Really not surprising but interesting post. It's a manual transmission and manuals suck at the drag strip.
I suspect it will give you the exact opposite feeling on a road course. Interested in your post after hitting the road course with your ZL1 experience. As fun as the ZL1 is on the road course, I suspect the Z/28 is that much funnier/better. |
04-04-2015, 06:11 AM | #10 | |
11.91 ET Bone stock
Drives: 2015 Camaro ZL1 Join Date: Nov 2014
It's the cars suspension and tire setup not the transmissions fault. The Z28 is a road course track specialist. |
04-04-2015, 06:34 AM | #11 |
Drives: 2011 ss Join Date: May 2013
This car is one dimensional and great at the road course. I believe that when advertised it's not recommended for a hard launch as in drag racing. That's why the OP that said it's a 11 second car completely stock faced so much opposition to prove it. I love the Z/28 and what it can do on a road course but it's not a car I would buy.
04-04-2015, 08:07 AM | #12 |
Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
Isn't the redline of the LS7 at 7000 rpm? I would shift right there.
04-04-2015, 08:25 AM | #13 | |
With a cam no doubt, shift at redline..stock not so much. Don't be to bummed on the drag strip numbers., tho the 110 mph trap is slighty down from published trap speeds...powering out of a corner on a road course is where the ls7 works best �� Side note: according to my scanners and dyno time with the car seems like the factory tach at least in my car..is a couple hundred rpm behind real world rpm readings close to redline For example the rev limiter kick in around 6800 tach reading...but the engine really doing more like 7k Last edited by MARKSTI; 04-04-2015 at 08:37 AM. |
04-04-2015, 09:40 AM | #14 |
Drives: 2013 silver ZL1 Join Date: Apr 2013
lets us know if the different tire set up works better
good info
2015 Z28 Black #16 600rwhp N/A
Colorado speed and performance build: hand ported heads, titanium valves, hand ported throttle body,fast lsxr intake, custom cut lunati cam, lunati push rods, fm high performance lifters, dual beehive springs + titanium retainers, trunnions upgrade, ARH headers + x pipe, fast fuel rails, c5r timing chain, katech high volume oil pump, ati underdrive pulley, Taylor wires. Sold---2013 ZL1 M6 Silver Ice Metallic: 767 rwhp |
