03-08-2015, 02:52 PM | #1 |
Rawr!
Drives: Giulia Quadrifoglio, C8 Stingray Join Date: Sep 2013
Catch Can installed! Some afterthoughts
So I purchased an Elite catch can, put it in today, and here's my thought.
For the LFX engine (2014 V6), it appears to be unnecessary. The PVC pipe that comes from the engine bypasses the throttle body and goes straight into the engine again to be burned. If there's gunk buildup, it wouldn't be from that particular pipe with the catch can. That's just an exterior observation. Would love to hear feedback from more qualified members, if my observation's wrong. I enjoyed installing it, and would thank everyone's feedback on a previous catch can post, which i can't find anymore on search. Awesome. Rawr, Kev
Current:
2023 Red Mist Corvette Stingray 2LT 2021 Trofeo White Alfa Romeo Giulia Quadrifoglio Retired: 2018 Garnet Red Camaro 2SS 2014 Crystal Red Camaro RS |
03-08-2015, 05:29 PM | #2 |
Drives: 2011 Synergy Green 2SS/RS Join Date: Dec 2014
I've read just the opposite, that the catch can is MORE of a necessity on the V6. My SS has 35,000 miles on it from the original owner. Still on the fence on whether to get one of these.
2011 Camaro 2SS/RS Synergy Green LS3/M6
Skip Shift Eliminator Vitesse Throttle Controller 2008 Toyota Tundra Double Cab SR5/TRD Independent Amsoil Dealer |
03-09-2015, 10:42 AM | #3 |
Drives: 2017 2SS, 2023 3LT RS, 2011 2LT RS Join Date: Aug 2014
Interesting. Where does the PVC on the '14 V6 lead exactly? (Without me having to take cover off to see myself)
03-09-2015, 10:48 AM | #4 |
Emerald Coast Camaros
Drives: 2010 Camaro 2LT/RS M6 Join Date: Nov 2009
The dirty side of the PCV will go from the rear right valve cover to the top of the manifold on the V6. When blow by occurs, it will fall into the manifold and collect in the runners and eventually run itself down and cause build up.
03-09-2015, 11:08 AM | #5 | |
Drives: 2023 Camaro 1SS Join Date: Apr 2014
There's different schools of though here on use of a catch can...some people are adamant that the V6 cannot live without one. I'm more in the camp that aside from oil in the PCV, there's still a lot of stuff you can't catch in the can itself, especially not the engine's EGR system (it doesn't really have one in the traditional sense, but it does take some exhaust gases and blows them back through the intake). So there's a potential for buildup in the intake anyway. Catch cans catch heavy oil vapor and other condensate. If you install one, don't forget to empty it, AND, still keep an eye out for garbage building up in the intake. The LFX is improved over the LLT-- I've heard of a handful of early issues with the LLT and intake garbage, mostly on the Lambda SUV's and early Camaro's. GM claims the system has now been optimized. 12k here, no catch can, and intake is clean. I realize my car is still very new. |
03-09-2015, 04:14 PM | #6 |
Drives: 2020 rally green rs Join Date: Oct 2013
I'm on the fence with this one too,2yrs old with 5000 miles so I don't drive it much maybe later.
03-09-2015, 05:18 PM | #7 |
Drives: '12 2LT Convertible Join Date: Mar 2012
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
03-10-2015, 01:18 PM | #8 | |
Drives: Chevys at the limit Join Date: Nov 2010
Also, there are 2 sides of the PCV system. Most of the problem is on the side that you installed the catch can on, but the other side can be problematic as well. During normal function, the other side (clean side) lets fresh air into the engine, however at WOT (wide open throttle) you'll get some reverse flow through the clean side, and that's what you find on the front side of the throttle blade and intake tube. For those who spend a lot of time at WOT, you can benefit from 2 catch can. If anyone has any questions, feel free to call, PM or email me anytime - I'm happy to help! Best regards, Tyler 888-308-6007 |
03-10-2015, 01:30 PM | #9 | |
Drives: 2018 Camaro 1SS 1LE Join Date: Aug 2014
Is this why I see what appears to be a check valve on the Z28 intake where the clean side seperator tube connects? Do you get that reverse flow on the other side where most dirty side catch cans connect? |
03-10-2015, 03:30 PM | #10 |
The LFX engine benefits the most from a catch can, for the reasons Evergreen6 stated. Direct Injection is the culprit. Don't get me wrong... the LFX is a great engine. It just runs dirtier than the LLT/LS3/L99. Look at your tailpipes and you will see what I mean.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
03-10-2015, 03:33 PM | #11 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
If you plan on keeping your car and wanting to run it's best you need a catch can.
Power is worthless without control. The 2nd protects the 1st.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
03-10-2015, 03:35 PM | #12 |
SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
The problem isn't the throttle body... The problem is that the LFX and LLT both have more than average oil blowby, and because they are direct injection this oil doesn't get cleaned up by the injectors on the valves and so it just builds up.
03-10-2015, 03:36 PM | #13 | |
Drives: 4 wheels Join Date: Mar 2014
_______________ In the absence of any major, wide spread reports of issues related to buildup addressed by the catch can, I've opted to not bother. As discussed in other threads, the V6 LLT and LFX engines are used widely across several models. Problems of the severity claimed by the makers and users of catch cans would be at least registering on our radars. That tells me these issues are, at worse, nominal in scope/frequency or limited to certain conditions (frequent high RPM use). Back to your regularly scheduled panic attack. |
03-12-2015, 01:53 PM | #14 |
Rawr!
many thanks for the replies everyone. I enjoyed reading the explanations.
i'll followup in a month or two when i have time to tinker with the engine again. rawr!
Current:
