02-23-2015, 01:19 AM | #1 |
Drives: 2015 Red Rock Camaro 1LT RS Join Date: Feb 2015
Passing tips for camaro with back seat blind spots?
Just got my 2015 camaro 1LT RS but wanted suggestions/tips for whenever passing or changing lanes due to large backseat blind spots. I moved the passenger seat a little forward so I can see the rear seat right backseat window but what's the best method for checking blind spot for the driver side?
Tia, Ian B |
02-23-2015, 01:23 AM | #2 |
Drives: 2010 Camaro 2ss/Rs Transformers Join Date: Aug 2014
You should get the little blind spot bubble's foe your mirror's. I have them and they work perfect.
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage LS3 conversion Vararam intake(tune model) Kooks LT headers & cats delete Corsa ZL1 3" exhaust RedBarn Racing Tune CMS Stage 3 Cam AFR CNC ported heads MSD Spark plug wires LNC-2000 Launch controller NGK TR6 Spark Plugs 1le strut tower brace-TPIS spacers Nick Williams 102mm throttle body Fast lsxr 102 intake manifold Slp 25% UDP Katech Tensioner Pulley Circle D 3600-3700 multi disk Stall GM 3.91 gears DDS carbon fiber driveshaft ZL1 fuel pump & injectors Flex fuel sensor(91/E85) https://wheelwell.com/kris-perez |
02-23-2015, 01:57 AM | #3 |
Pro Hide n Seek Player
Drives: 2010 SS LS3/LSA 620whp/630tq Join Date: May 2009
There are no blind spots if you set your mirrors correctly.
620whp/630wtq. ADM LSA Conversion, E85, PFADT Tri-Y Headers into Borla S, PFADT Swaybars, Springs, Links, 20x10 20x11 Forgestar F14s, Lots of AAC |
02-23-2015, 01:58 AM | #4 |
02-23-2015, 03:15 AM | #5 |
Drives: GM car Join Date: Jul 2014
What I do is lean forward as much as I can and then check over my shoulder.
02-23-2015, 06:00 AM | #6 |
Drives: The red one Join Date: Jan 2015
I agree with setting the mirrors correctly. I haven't had any problems with blind spots but it does take a little getting used to. Never thought about the little bubble mirrors. Those would seem to help, too.
What worries me more are right turns when there is a high curb. Those are kind of hard to see. I find myself making more of a "square" turn, or just going around the block and make a left instead, LOL. |
02-23-2015, 06:44 AM | #7 |
Moderator, please merge or delete this thread as created up in error.
Sorry everyone. Ian B |
02-23-2015, 08:41 AM | #8 |
I take corners way wider in this car then my other car. I curbed my tires twice on the curb before doing this and ever since taking wide turns I haven't curbed my tires. It takes some getting used to but you develop a kind of 6th sense of where your wheels are after a while.
02-23-2015, 09:19 AM | #9 | |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
02-23-2015, 09:55 AM | #10 |
Drives: C6 Corvette Join Date: Sep 2013
Drive faster.....guarantee no one is in your blind spot when they are all being passed lol
2008 C6 m6. Carbon creations front/rear carbon fiber wodebody fenders. Carbon fiber hood carbon fiber roof hoop carbon fiber zr1 extreme spoiler. NW 102mm tb. Ported intake manifold. Cometic .040 head gaskets. LG motorsports G6x3 cam. DSX flex fuel sensor. AEM methanol kit. Z06 brakes. Ebiach sway bars. ZR1 rep wheels and Nitto Invo tires. Monster stage 3 twin disc clutch. MGW short shifter. Corbeau race seats. Gforce race harnesses. SLP loudmouth 2 mufflers. Carbon fiber exhaust tips. RPM stage 4 transmission and Stage 3 rear diff. 3.73 gears. Vararam cai. Kooks 1 7/8 headers and x-pipe.
02-23-2015, 09:58 AM | #11 |
Homeless Life Chose Me
Drives: LS3 (sold 4/21) Join Date: Nov 2014
Ya just mash the accelerator.
Pity a man in familiar places, who yet feels like a stranger.
02-23-2015, 10:02 AM | #12 |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
Volvo has an amber light built into the mirrors that lights up when another car is to
your left or right rear 1/4 panel. Works really well and I wish that it was on the Camaro.
02-23-2015, 10:06 AM | #13 |
Drives: 2010 Camaro SGM 1LT M6 Join Date: Jan 2015
02-23-2015, 10:12 AM | #14 |
No matter what you say here some YaHo will chime in to disagree...
