02-12-2015, 12:10 PM | #1 |
SoCal HT5
Drives: 2010 SS , 2014 SS Join Date: Sep 2011
6th Gen newest rendering
hey guys , this is my attempt to get everything together ( headlight , bumper )
I've used ACS composite's bumper in the rendering , and the new 2016 headlights that were revealed , results look great , what do you guys think ? |
02-12-2015, 12:12 PM | #2 |
The BBOMG fill-in husband
Drives: 2015 2SS/RS 1LE AKA V1LE Join Date: Aug 2010
Not bad
UPSTATE C5 MEMBER
02-12-2015, 12:16 PM | #3 |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
That's probably pretty close. I'm not sure how I feel about it.
02-12-2015, 12:18 PM | #4 |
Drives: 2011 Camaro 2ss Join Date: May 2013
I'd hit it
02-12-2015, 12:22 PM | #5 |
Drives: Coupeless :( Join Date: Jan 2015
You did a good job. It looks a lot more like the Transformers car than I would like though.
02-12-2015, 12:24 PM | #6 |
2010 2SS/RS M6
Drives: 2010 2SS/RS M6 Join Date: Jun 2010
Overall it looks pretty good. A couple of critiques though: looks like you went with an aftermarket hood as it has the louvers by the windshield instead of the vents seen on the camo car and the fog lights look like they are "cross-eyed" and pointing too much to the center.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter Bumblebee Racecar Build |
02-12-2015, 12:45 PM | #7 |
Romans10:9-13
Drives: /\yes, this is me/\ Join Date: Nov 2008
Smooth out the area between the brake duct & head lights. not so many different angles & levels.
02-12-2015, 01:08 PM | #8 |
Drives: Sedan Join Date: Oct 2014
Very well done. I like the crease you added between the bumper and headlights, it makes the headlights fit better. That could have been covered by cardboard and camo, so I'm not discounting it. I'm thinking the vertical crease that goes up from the fogs was cardboarded up and is a little more deep than what you've done.
Credit to me is not necessary, you didn't use any of my actual pixels, just the impression of shapes. Thanks, nonetheless. |
02-12-2015, 01:16 PM | #9 |
Looks nice but not close to the car, to much aftermarket parts to be from GM, hood is way off look at today pics, but all in all its a nice job.
02-12-2015, 01:24 PM | #10 | |
Drives: none Join Date: Aug 2014
02-12-2015, 02:36 PM | #11 |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
This is a shot of the TF4 car (hence the creases below the headlights) with the bumper modified and the leaked headlamps photoshopped into place, (and the color hue changed a bit)
I did something similar months back. I think this could possibly be close, but who knows? Here is the crappy one I did:
2010 Camaro 1LT V6 (Sold. I will miss her!) |
02-12-2015, 02:39 PM | #12 |
Drives: 13' 1LE Join Date: Apr 2012
Nice try, I like it!
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
02-12-2015, 02:44 PM | #13 |
Drives: 2016 F150 Join Date: May 2014
I really don't like it.. Hope that's not it. :( I don't think it is. Small details will make a difference.
02-12-2015, 02:49 PM | #14 |
Drives: 2010 Camaro SS Join Date: Dec 2014
I hate the squinty head light look!
