Vararam
Old 01-23-2015, 05:45 PM   #1
johnjohn
johnjohn's Avatar
Drives: 2010 ss
holley mid rise or stay with stock ls3 intake???
will the holley mid rise intake make more power over the ls3 on a stock bottom end cam only ls3??? 14 psi
2010ss L99 to a ls3 s480 turbo lil john cam tuned by james short
johnjohn is offline   Reply With Quote
Old 01-23-2015, 06:37 PM   #2
BGKySS
BGKySS's Avatar
Drives: Cyber Grey 2010 2SS RS
Subscribed, I have the mid rise and will be adding boost to the mix soon.
2010 2SS/RS
-Headers, catback, Holley Mid-rise and a 150 shot-
BGKySS is offline   Reply With Quote
Old 01-23-2015, 06:40 PM   #3
402
Drives: Camaro
I wouldn't even waste your time. Run stock manifolds over 1000 all the time.
402 is offline   Reply With Quote
Old 01-23-2015, 06:44 PM   #4
Unreal
Drives: 2006 Z06
Agreed.
Money better spent elsewhere.
Nick
Corvette Z06 -1200ish rwhp
Unreal is offline   Reply With Quote
Old 01-23-2015, 07:47 PM   #5
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
I wanted the Holly so bad. Really just for the fact that it looks Bad Ass. But my tuner said he wouldn't tune the car if I wasted my money on it . Said more then likely it would do more harm then good.
Nitroman28 is offline   Reply With Quote
Old 01-23-2015, 08:35 PM   #6
jrpxxii
jrpxxii's Avatar
Drives: 2010 Camaro SS/RS 427ci
LOL You aren't going to do any harm but it might not make any extra power but its your money to do what you want. If your tuner has that much control over your car Id find a new tuner
jrpxxii is offline   Reply With Quote
Old 01-23-2015, 09:09 PM   #7
SuperchargedStealth
Drives: '11 Camaro Supercharged Convertible
Unless you're going to make huge power, it's not worth it. You only see gains on the high end of the power band. So to see any significant increases, you would have to spend most of your time driving it that way. Do something like that when and if you do a big build, but even then it would be for more aesthetic purposes.
2011 Triple Black SS convertible, LSX 427, PRC 260cc heads, Callies Ultra Billet Rods, Wiseco -20 cc piston, Callies Dragon Slayer crank, Strange Dana 60 rear w/3.73 gear ratio and driveshaft, Pfadt coilovers, Pfadt sway bars, Pfadt trailing arms, Pfadt tie rods, Pfadt subframe bushings, Vortech YSi with wastegate and twin BOV, Haltech ECU, Mantic 9000 Twin Clutch, ALKY control meth system with dual nozzle, Squash twin fuel pumps, ACS T3 ports, VIS Terminator Hood, Seibon ZL style lip.
SuperchargedStealth is offline   Reply With Quote
Old 01-24-2015, 07:41 AM   #8
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
Yeah...that's a bit extreme
-John S.
grocerygetter is offline   Reply With Quote
Old 01-24-2015, 07:46 AM   #9
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
Two things. 1) it needs to be machined to fit. 2) this thread... http://www.camaro5.com/forums/showthread.php?t=393085
Sent from my SM-G900V using Tapatalk
Firefighter is offline   Reply With Quote
Old 01-24-2015, 08:55 AM   #10
Nitroman28
Nitroman28's Avatar
He just knows I like to waste money. And not tuning it was a joke. When the new motor is done it will get one.
Old 01-24-2015, 09:46 AM   #11
Stingr69
'69 Owned Since '79
Stingr69's Avatar
Drives: '69 Z/28 LeMans Blue w/White
You will not be limited by the intake stock or aftermarket intake either way. You will be limited by the fuel octane and quantity. The tuner will be adjusting the tune to give max combustion efficiency given the limitation of the fuel quality. More flow is a pulley swap and the supporting mods. Why "fix" something that ain't broken?
Stingr69 is offline   Reply With Quote
Old 01-24-2015, 09:56 AM   #12
johnjohn
johnjohn's Avatar
Drives: 2010 ss
thanks guys,,,,
ill just keep the stock intake till i built a motor
Old 01-24-2015, 03:54 PM   #13
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Yea, when I asked about the manifold change possibility, I was just basically told "want more power, turn up the boost". Made sense, unless your shooting for a certain look, or just want to do it because.
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
