01-14-2015, 01:24 PM | #1 |
Holly Valve Cover and Coil Packs
Can I buy this HOlly Valve Cover - https://www.holley.com/products/acce...s/parts/241-91
And also keep coil packs in their stock location? I will be removing them to paint them, and actually sort of like that look, but wanted to make sure the Holly cover still works with coil packs in stock location. Thanks in advance -
Cold Air Inductions CAI Stainless Power LT's with HFC's Flowmaster American Thunder Cat Back APEX Scoop and WW Relocation Kit VMAX Ported Throttle Body Custom Dyno Tune Pfadt 1.25" Lowering Springs ZL1 Rims on 275 front 315 Rear custome underlay vinyl wrap Anvil Spoiler heritage grill APR Front Splitter Custom Emblempros emblems ZL1 Side Skirts 416.5 whp 410 torque (CURRENTLY) Up Next: BTR Stage 3 Cam and supporting mods (in garage now)
01-14-2015, 01:31 PM | #2 |
Too much is never enough!
Drives: AGP TT SS [COTW] 4/20/15 Join Date: Feb 2014
Don't see why not, according to the website there a fit, of course you already know that, but they look identical to what is already on the car.
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread http://www.camaro5.com/forums/showth...55#post8107855 |
01-14-2015, 02:05 PM | #3 |
Thanks for reaponse I've been reading a tom of threads and I believe you did an engine clean up project also. Do you have that thread? Wanting to tackle this weekend. What all did you do?
01-14-2015, 02:09 PM | #4 |
You must be thinking of someone else, I haven't done anything like that yet. Nice valve covers by the way, I am thinking about picking those up now, thanks to you!
01-14-2015, 02:13 PM | #5 |
Sorry I swear I remembered your handle! Yeah I'm hoping they will work with stock Coul pack location so that painted with cool packs painted and maybe plenum cover painted should add nice touch
01-14-2015, 02:47 PM | #6 |
Nothing about our engine really pops when we open the hood. It's just a bunch of wires. The engine cover doesn't do anythign to help, either. Those valve covers look great. I've been thinking of ordering the coil pack covers, that look like value covers...
01-14-2015, 02:56 PM | #7 |
Yeah I have seen those too also by holly but love the look of them painted. Then with valve cover somethin like this
01-14-2015, 03:05 PM | #8 |
Drives: Race Car Join Date: Sep 2009
I have the polished aluminum Holley Valve Covers on my car. The coils mount directly to the valve cover without all the brackets underneath. I really like them, especially for the cost.
01-14-2015, 03:14 PM | #9 |
Drives: 2010 Camaro 2SS/RS Join Date: Aug 2012
Paint the stock valve covers. Cost me less than $20 to paint mine.
2010 Camaro 2SS M6
2" Stainless Power Longtube Headers 3" Full exhaust w/ Off-Road H-Pipe Bo White Ported Throttle Body Hurst Short Throw Shifter Best Time: 12.43 @ 114, 1.99 60' on stock wheels and stock tires Build Thread |
01-14-2015, 04:10 PM | #10 |
Djpelosi that looks amazing maybe I'll go that route and save a few hundred. What else did you paint? Do you have a DIY?
01-14-2015, 04:15 PM | #11 |
Drives: 2007 Corvette C6 983 RWHP Join Date: Dec 2011
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam YSI / 3.0 pulley, ARH 1 7/8 headers, NPP Dewitts / dual spals, A&A dual pump fuel system. 3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me. ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper Circle D Triple Disc stall 1009 RWHP @ 7000, 817 RWTQ @ 6000, |
01-14-2015, 04:22 PM | #12 |
Do these fit over stock valve covers or just replace them? I really actually like both looks
01-14-2015, 04:55 PM | #13 |
No DIY really... just sand really well and put 4 coats of primer, paint, and clear. Getting the valve covers are easy.... just a few bolts.
2010 Camaro 2SS M6
01-14-2015, 06:08 PM | #14 |
That's what I meant how to remove valve cover. Seems to be a lot of crap in the way?
