01-07-2015, 02:01 AM | #1 |
Drives: 2014 1SS RS 1LE tvs2300 Join Date: Jun 2014
SLP SC install
So close.
Still need to: -Fill with coolant -Install wideband -tune -install 10 ounce clutch fluid reservoir My goal is a really fun daily driver. I used to drive it as long as there was no snow not he ground, but I may change it to no salt. I have michelin AS3s sitting in the garage, which are going on as soon as car is tuned. Not sure when that will happen weather in Maryland could be better. Last edited by z3R0fo01; 01-07-2015 at 04:01 AM. |
01-07-2015, 02:06 AM | #2 |
more pics
01-07-2015, 04:32 AM | #3 |
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM Join Date: Oct 2010
great job.
Easiest supercharger to install. |
01-07-2015, 11:32 AM | #4 |
Drives: 2013 2ss hot wheels camaro vert Join Date: Jun 2013
your going to love it!!
SLP SUPERCHARGER,3.6 PULLEY..HEADERS,HIGH FLOW CATS,BORLA S CATBACK,CAI INTAKE,ZL1 FUEL PUMP,ELITE CATCH CAN,TUNED BY PHIL AT TAMPA TUNING
01-07-2015, 12:23 PM | #5 |
Drives: 2010 Camaro SS Join Date: Dec 2006
Looks good!
01-07-2015, 07:19 PM | #6 |
Drives: Supercharged 2013 AGM 2SS/RS Join Date: Oct 2013
Looking good, enjoy!
2013 AGM 2SS/RS
SLP TVS2300, Edge CAI, 3" Magnaflow catback, BC Racing BR series coilovers, HRE FF15's (20x10 square) with Michelin Pilot Sport 4S's, GM STB, BMR front and rear sway bars and toe links, Prothane subframe bushings and front control arm inserts, JDP rear upper control arm bushings, Elite Engineering catch can. Tuned by Cunningham Motorsports. 1967 Bolero Red 396 SS/RS Convertible |
01-07-2015, 07:26 PM | #7 |
Drives: 2013 ZL1 ADM 750 Join Date: Dec 2014
That is going to be a fun car for sure. The salt on the roads is crazy now.
It destroyed the clearcoat on my trucks wheels last winter. Nice set-up! |
01-07-2015, 08:49 PM | #8 |
Thanks guys! I just used my new airlift vacuum filler and started the car. It idled and then I had to cut it off because it was sucking fumes in house. Running rich and no cats= lots of fumes!
Oh yeah, running Jannety base tune until I can do some data logging. Intune and wide band data logging as soon as the weather is somewhat decent. Here the link for anyone interested in airlift, it makes life much easier: http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1 |
01-08-2015, 10:23 PM | #9 |
Drives: Pending Join Date: Dec 2014
01-08-2015, 11:16 PM | #10 |
-No need to take bumper off
-Hoses are precut and coolant lines are preformed -No need to pin cranks if using stock pulley (belt will slip before any damage can be done, theoretically) -Intake manifold and supercharger are separate, meaning no heavy lifting across engine bay (I did the entire install by myself) -only need to get under car two or three times -hardest part is getting the water pump in but still not all that difficult just a little tedious -wiring is all plug and play (need to crimp one wire to tap switched power source in main fusebox under the hood)
SLP TVS 2300 Kooks 1 7/8" Rotofab intake NPP
JRE tuned |
01-09-2015, 10:35 AM | #11 |
8.60 @ 157 @ 4200lbs
Looks great if you need any help with anything let us know
01-09-2015, 11:24 AM | #12 |
Jim
Drives: 2013 Black 2SS 1LE Join Date: Apr 2013
okay stupid question
Don't know much about supercharger brands etc. Is slp the name of a brand or a type of supercharger. I hear, Maggie, whipple, etc. Is the SLP a brand like them, do they all make their own? I also hear the name Eaton and it seems they make superchargers for others. Confused Jim
Jim's Mongoose, 2013 1LE with Airraid CAI and PTB, mild to wild switch, and Vitesse throttle controller.400RWHP on Mustang Dyno In Phoenix, AZ on a 75 degree day.
01-20-2015, 06:33 PM | #13 |
The SLP is the name brand that uses an Eaton tvs2300 to build their supercharger. A maggie also uses the same rotor packs in their superchargers. The whipple is a screw type instead of a roots or blower type. Gm also uses eaton internals in their supercharged cars.
Also, update: I was running out of fuel pressure and running lean at wot throttle. I was advised by Ted to go with a BAP, but instead, I came to my senses (not that it wasn't sound advice). I am changing the pulley to a 3.6 and going with a squash return style dual pump. In a year or so who knows... Time to drop the tank and have some more fun working on the car!
JRE tuned |
01-20-2015, 06:42 PM | #14 |
Drives: 96SS Join Date: May 2009
Feel free to give us a call if you want a real tune on that thing. We will do a before and after on the dyno for you.
